Most of his upgrades look to be for durability not Bling!-That truck will rail!!!Even with hop ups the box stock set up, as far as shock position, is very easy to do!!!I built my truck in pieces wondering if (Iron Wolf) will spill the beans about how much went to build that Beauty???Looks like everbody is going to bleeder caps,I stripped out a-head and cant find a source local any whereBack order at Losi for now tooo!!!Booo!!
+1 ok i'm just going to go to amain do a search and, WHAT BACKORDER?!??!? Totally sucks when sellers don't have what you need. Every time i go to my amain account i see one of of my backorder items came in and another one just went out of stock.
what parts are you guys looking for?
No breakage, just unecessary upgrades that won't make a noticeable difference at all.
"oh hey, just put a tekno driveshaft and anodized ball ends and i can't tell a difference at all when i'm driving. So glad i spent that $75. But hey it looks pretty and that's what counts."
but seriously 90% of the items in my cart are a want and not a need.
Chassis 100
Screws 90 (stupid expensive)
Turnbuckles 30
Tekno Drives Ill say 80
Esc 200
Motor 100
Servo 70
TLR Tuning 120
Kingz Head Mid Top Plate 20
DE Mudgaurds 8
SO....ALOT. 1100? Alot. I just hit the buy button and went on lol.
I know I need rod ends badly right now, and guess what? yup. The dreaded backorder. I have heard that people are running 8 series rod ends with the HA pivot balls. Anyone know if those rod ends will work?
http://www.amainhobbies.com/product_...d-Set-15-Ten-T
http://www.amainhobbies.com/product_...ot-Ball-Set-16
I use the end links from a traxxas rustler. I had some new ones laying around. The holes in the balls have to be slightly drilled out but they have lasted much longer than stock losi ones ever would and no slop.
since w are talking about rod ends and ball joints.... when a set up sheet says bump steer up....what exactly is that pertaining to?
There's a flange on one side of the steering ball ends. Compare that to the illustration on the setup sheet - I run the flange down which is pretty much what all setups have. Flange down is bump steer up and flange up is bump steer down.
Unsolder Motor Connections?
This may be a dumb question - certainly won't be my last one LOL...
When you guys work on your motor, taking it apart to clean it or replace bearings or whatever, do you typically unsolder the wires and then resolder when you are done or leave them connected and work around them?
Its easiest to un soldier it and clean it ... just dont heat up the tabs on the motor too much.
