R/C Tech Elite Member
And a Quick question...mine was an 810 now a SCTE so do you think the axles and 17mm hexes stick out farther than the 12mm stock SCTE Hexes would? The 1/8th scale rims look like they might hit the body but did order and do have scte axles and hexes but no scte rims/tires yet
Thanx Chris!!
Thanx Man!
My goal for this part was to add Bling to that ugly plastic part & eliminate the 2nd part that fit underneath. Also to make sure the part has no negative effect on handling.Pushing, or too stiff side to side etc. This protype is 2 grams heavier than the plastic parts but is thin enough to have simular flex characteristics.
I will get it on track tonight and the next two days and run it thru the paces.
If there is a performance advantage I will be surprised as I am only hoping for no disadvantage as of now.Ano blue or red or green and I think it would be sick!!Again My goal was for Bling only!!!!
Thanx Man!
Hmm.. my gut says bumpers, but my brain says that while many people seem to complain, I don't know if it's 10k worth! Hmm..
I'm guessing a split center diff, or something to do with diffs.
Also Ryan what's the weight of your truck? When using the setup sheets on the site I wish the weights of the trucks were listed. If your truck weighs 6lbs rtr and mine is 6.5 or heavier the two will handle completely different with your setup.
10,000 units... hmm...
1) Rear bumper (I'll buy 2 for starters myself)
2) Smart diff's (I'd buy 4; 2scte, 2 810e)
3) New sliding and lightened battery tray (again 2 units; one for my scte, one for my 810-e)
4) Alum front spindle/carrier (hmm typical losi hop up, but not on my list)
5) Front universal drive shaft
Thats about all I can think of.. that would get that kind of attention
I hope for #4 on eight's list.
As for the parts, i have the hexes and axles...are these the PITA that everyone talks about getting apart and using chainbreaks and whatnot? I hope not cuz i should have just ordered the 4 axle assemblies off ebay with some of my other parts
Oh, and here is a pic to prove its the 4700kv that I posted about Blitzrockey even confirmed. But as a hobbywing dealer you should kno this...
Last edited by TCCustoms; 06-01-2012 at 07:46 PM. Reason: haha, forgot to add the pic link....DUH ME!
I am also hoping for a new "smart diff".
So, what is a smart diff?
Have you guys noticed that the stock body posts snap off like crazy? Seems like everytime i have a bad landing these are the first things to go. Does anybody make an aftermarket set for the scte?
