Got the Viper Copperhead installed. Really nice esc, very well built. Running R45 motor geared 14t
If this system is as durable, it will seriously be a steal at $150+-
When r these gonma hit the shelves?
OK been running an LRP TC v2 and a Tekin 4.5 and 13t pinion radio turned down to 84% (we run a very small indoor) and temps after 8min main were about 135*motor and 95* speedo. Well swapped in the 4000 4pole with a 14t pinion and turned the radio up but no other changes and temps shot up to 170* speedo still under 100* tried a 13t and 15t and temps about the same?? Where should this motor be geared? Almost want my 4.5 back but was hoping this motor was smoother and easier to drive.
Next I got an Orion 10Rpro to try but was hoping to figure this out before swapping more problems.
Slap a fan/ heat sink on it and drive it like you stole it ?:@)
OK been running an LRP TC v2 and a Tekin 4.5 and 13t pinion radio turned down to 84% (we run a very small indoor) and temps after 8min main were about 135*motor and 95* speedo. Well swapped in the 4pole with a 14t pinion and turned the radio up but no other changes and temps shot up to 170* speedo still under 100* tried a 13t and 15t and temps about the same?? Where should this motor be geared? Almost want my 4.5 back but was hoping this motor was smoother and easier to drive.
I am picking up a SCTE for my LHS tomorrow. I have decided on the Motor and ESC combo well sort of. Have to decide between a Tekin Pro4 4000kv or 4600kv with a RX8 ESC. The thing I have to decide on is a servo for it.
So I thought I would ask the people with a good knowledge of this to see what do they recommend to be a good servo for this I have been thinking of a Savox or Spektrum model but not sure what torque rating I would need.
Your set-up is identical to the set-up im using right now. Just purchased the Savox 1258 ( .08 / 167 oz. ) for my set-up. I had two servos to choose from. The 1257 ( .07 / 139 oz. ) and the 1258. Both were the same price at my LHS, so I decided on the 1258 because of it's higher torque reading.
Thanks for the heads up.... I take it the Savox or Spektrum have more than enough torque @12kg for it?
Registered User
Got spektrum s6020 w/ 146 oz torque for 45 bucks at main hobbies.
Losipartshouse has the HA balls and shock bodies.
