TLR 22 Racing Buggy Thread >
Like Tree3Likes
Old 03-23-2012 | 06:41 PM
  #14866
Default Losi 22 rtr Throttle stopped working
Hi everyone,
This is my first time posting here. I just bought a Losi 22 and after driving it for about 5min in my backyard the throttle just stopped working. I took it inside and noticed that the steering still works. The motor was still cool but the ESC was hot to the touch. I just bought this car and this was my first run.
The battery I'm using is a Traxxas 7 cell 4200Mah 8.4v battery that the hobby store employee recommended
I was driving the car on flat grass, I'm from Canada, so the grass was still packed down from the snow. Also, The car was in half throttle mode. My backyard is pretty small, so I wasn't even able to reach full throttle.
Has this happened to anyone else? I'm thinking of sending it in for repairs and I'm wondering if the ESC is covered by the warranty. I know the ESC is dead because I took it to the shop where I bought it and they tested it.
OfTheBor is offline
Old 03-23-2012 | 07:29 PM
  #14867
I just built up my 22 last weekend and drove it 3x now. I absolutely love it.
When I first built it one of the things I loved was how slop free everything felt, but now I'm noticing some front end slop.
I'm still learning to drive and bounce off the pipes/wall from time to time. I've noticed a fair about of front end play coming from (what seems to be) the ball cups when I wiggle the front wheels side to side. Is this normal? Is there an upgrade (RPM) ball cup that is a little more durable? They're not broken just sloppy which seems kind of quick.
I understand that once I stop bouncing off things this may be a moot point, but I need some help until I get to that point.
Thanks!
augie walker is offline
Old 03-23-2012 | 09:40 PM
  #14868
K5DTE's Avatar
Guys,
I am working on setting up my 22 per the Frank Roots standard setup. All of my parts arrived yesterday and I got to work on it this evening and have a question.
Does the 25* brass kick shim just get stacked along with the stock 20* shim? To me it is the only way that it makes sense as the brass kick shim is the same thickness front and back.
Did I install it right or am I missing something?
Robert
K5DTE is offline
Old 03-23-2012 | 09:55 PM
  #14869
bergie33's Avatar
Originally Posted by K5DTE
Guys,
Robert
Remove the 20* shim. The 20* shim offsets some of the natural kick in the 22 chasis. With the flat design of the 25* shim, it results in a steeper overall kick.
bergie33 is offline
Old 03-23-2012 | 09:57 PM
  #14870
K5DTE's Avatar
Ahh, that makes sense. Thank you sir!
Robert
K5DTE is offline
Old 03-23-2012 | 10:03 PM
  #14871
RShockley's Avatar
The front kick of the chassis is at 25* so the shim needs to be flat.
RShockley is offline
Old 03-24-2012 | 03:38 AM
  #14872
Originally Posted by OfTheBor
Hi everyone,
Hmmm, Im not sure about the specs on the rtr esc. Im not sure if its rated to handle an 8.4v pack. If it is not, then i would say the hobby shop owes you a new esc and a trade in for the propper 7.4 pack. See if you can find anything in the manuals that give specs for the esc, and or maybe someone here knows
EDIT: i just looked it up and it does work with an 8.4 pack. I would call Horizon and talk to them about it as it should be under warranty, or if your hobby shop is good, they will take care of it for you.
Sean B. is offline
Old 03-24-2012 | 09:33 AM
  #14873
mtman75's Avatar
Does anyone know were I can download a PDF of the kit manual. All I can find is the PDF of the RTR version and not the kit? Thanks in advance.
mtman75 is offline
Old 03-24-2012 | 09:37 AM
  #14874
Briguy's Avatar
http://www.petitrc.com/setup/losi/se.../22_Manual.pdf
Briguy is offline
Old 03-24-2012 | 09:43 AM
  #14875
mtman75's Avatar
mtman75 is offline
Old 03-24-2012 | 09:44 AM
  #14876
Briguy's Avatar
No problem
Briguy is offline
Old 03-24-2012 | 03:26 PM
  #14877
Suspended
Great day of racing today. New track layout, Frank Root starting setup was money again. No changes were made all day. 1st place every round, TQ and 1st in the main.
h8thatadmin is offline
Old 03-24-2012 | 03:27 PM
  #14878
Nice. what's the grip level like for your track?
Bob Barry is offline
Old 03-24-2012 | 03:28 PM
  #14879
mtman75's Avatar
Nice were are you racing at?
mtman75 is offline
Old 03-24-2012 | 03:59 PM
  #14880
Suspended
I would call it medium grip, once the track grooves in. Today, because it was the first day on the new layout, I started on Green JC Goosebumps with Green Groovies up front. That was for Q1 and Q2, During the break between Q2 and Q3 I tried Gold V1 Barcodes, with MC Scrubs up front (my go to combo). The Scrubs had just a touch more steering (which I was looking for), and the Barcodes were working good too, so I stayed with them for Q3 and the Main. The Gold JC Barcodes are most consistent as the moisture changes (not much of a problem in the winter), but pretty much any of the clay compound bar style tire work fairly well. Today was the last round of our 13.5 buggy points series, so I was running 13.5, but my runs would have put me TQ in Mod also. It was strange, normally I go to Green Double Dees as an interim step between the Goosebumps and Barcodes, but the track grooved up really quick this time. I think they kept the dirt a little more wet while packing the new layout, and sprayed WD40 on the dirt to keep it from sticking to the packer. I guess for like the first 20 laps last night the track was a skating rink.
Addiction R/C
