TLR 22 Racing Buggy Thread
For those of you with questions on building ball diffs, this is a great video i found: http://www.youtube.com/watch?v=EToj2yX76NU
Are savox servo horns compatible with any other servo horns like JR or Futaba? Where can i find a losi 22 servo horn for the savox?
Savox uses Futaba 25T
sweet!!! thanks for the link zipper foot..i broke my motor(17.5) in with a 26 tooth..moved up to a 31 tooth..i think i can go much higher..im running on med-high bite clay track at lrh..we will se how we do once the 22 touches..i can't wait to see this baby on the track..i do want to be able to pin the throttle the whole time..lol ill give y'all some feed back when i get back..yall think i should go higher than a 31 tooth? i read someone went 35/70 is the ratio the same mine is at 31/76??
I am sure someone will chime in with a good staring point. For what it's worth, I practiced with a guy running a 17.5 over the weekend. I don't know what gear ratio he was using but he had no trouble keeping up with a 13.5.
Just keep in mind the taller the gearing the more you have to watch your motor and ESC temps. I would say start with the 31 and see how it feels. If you want more you can always ad on from there. As far as a 70t spur, I have yet to find one in stock.
My 17.5 Ballistic is geared with an Associated 72 tooth spur gear and slipper pads with a 32 tooth pinion. My motor temps are around 140 after a 6 minute run.
My version of the TLR 22 diff wrench. I have had this old driver handle for years and finally put it to good use...
I have absolutely zero experience with a 17.5. I have always run mod motors and recently went to a 13.5. It took a little getting use to. When the car went down the straight I felt like I had enough time to go make a sandwich.
thats cool temps..i think u r 20 degrees below max..well I'm running the stock 76 with a 31..ill test it..thanks!
is that a 2.00 MM?
very nice i like..
I had no problem keeping up with mod buggies on smaller tracks (RCHR). On the larger tracks, I didn't have the same top end, but still put down comparable laps to the mod buggies (RCE).
Whats a good starting pinion for a 75 Spur, 10.5 motor, 100x60 track clay?
Have to ask yourself. Self, why didn't we think of this?
Yes sir or 5/64
The handle is BOLINK brand I believe. It is probably as old as a lot of the members on here.... haha
Yes sir or 5/64
