TLR 22 Racing Buggy Thread
my slipper wont say set the nut backs out after a run?
Just started the offroad scene about a month ago and another happy 22 owner here.. ran the kit in stock setups rear motor for a fun race & manage produced pleased results. Powered by a 8.5T Tekin n it handles so well. thanks to the friendly local guys that guided me n shared their knowledge
losi 22 mid motor
i just got a losi 22, and im racing it in the mid motor on a clay in door track , anybody have a good set up or advice on mid motor set up ...
thanks
thanks
sorry new nut and lock tight
R/C Tech Elite Member
Here is a list to convert to mid motor
4-gear transmission case
Rear shock tower mid motor
Wing mounts mid motor
Chassis brace/ESC mount
Rear bumper (may come with above)
Rear bulkhead mid motor
Idler gears (comes with aluminum posts)
Two idler gear bearings
Body (cut out for mid motor)
And if you plan to use HRC blocks as most of us do on carpet then you will need HRC anti squat tuning kit
yup
How does he get the nose to drop so nicely over the jumps. Mine seems to want to go slightly nose up all the time. Im glad when it comes down level. Cant seem to find the right throttle combination to get the nose down consistently.
Of course Im used to 1/8 where a tap of the brakes drops the front end easily. this 2wd stuff just doesn't respond in the air so I guess I need to work on setup and the right approach on the jumps. Any advice?
Help..... Rear motor build help! Suspension Assembly
Please turn to page22 B-3 of the losi Manual.....
the two screws secure to what?
Through the spacer(2044).. through the alu. pivot peace(1065) with the plastic oval(2046) in it.. then what?? No threds past it what holds it all together. The rear motor does not have thredded hole location... what am i missing?
Mid motor it screws into motor..... but Rear motor I cant figurre it out?????
This is the rear underside of the rear motor setup!
Seth
Tick tock
3D-Seth, bombertodd, dfsc10, jsorwell, porkchop, rc1racer, ruknd, slovanova
