TLR 22 Racing Buggy Thread
I think it is an .050
Probably a 1.5mm, it's metric.
Thanks guys. It's not a 1.5mm, got one and it does not fit. I'll try to hunt down a .050". I looked in the manual but didn't see it, guess I should look again!
Edit- Found it on page 10, .050". I see that MIP is selling a 1.3mm now, which converts to .051".
It on manual page 10
My new TLR 22!
[IMG]
[IMG]
The losi/tlr tungsten carbide diff and thrust balls are awesome (tlr2951,tlr2947)
Mr. Hodge thank you for the clarification regarding the legality of the movable battery tray. You just saved me from buying 14 packs of foam blocks.
Wolfson, & Rob Martin, I need some tire and setup info for McCullough’s. When I do finally get this car together (which is my first Losi 1/10th scale since around ’05 from what I can remember) I don’t want to look like to much of a fool on my first run there.
I have only run the shorty packs for many months now since the 22 came out. The car works so well with the short Xcelorin packs and I have that I haven't found the need to even try a normal sized pack in my car yet.
TLR 22
Xcelorin Short Lipo Packs
Orion R10 Pro ESC
LRP 7.5 motor, geared 76/22
Indoor Clay High Bite track mainly
TLR 22
Orion R10 Pro ESC
Diff Setting
Frank/Matt C./Casper -
Curious as to how tight you are running your diff. Assuming from a complete tight setting (spring compressed), how many turns are you backing off?
Rear white spring - what do you feel you are gaining with running a softer spring vs. the yellow?
Thx!
Thx!
The 22 likes to have its diff run pretty darn tight almost clamped, with a loose slipper.... I have been running mine like this from day one and my diffs last for days!!! A softer rear spring will give traction at that end...
Thx!
Thx!
Frank may do it a little different.
I try to not bottom out my diff spring. I usually sneak up on setting the diff using the tire flick method. Kind of hard to describe but it comes down to a fell setting. Basically I hold the spur with my thumb and turn one tire and watch the rotation. I want about 1-2 rotations of the tires with a good "flick" I then set the slipper form there. I might adjust the diff a little more if I can't get the slipper the way I want it but this gets me close. Make sure you "work" the diff as you tighten it so you don't dent the diff rings. It is not easy to dent the diff rings but if you just slap it together and then crank down on the diff screw it can happen. You always want to work in the diff and break it in before you get to final settings.
