TLR 22 Racing Buggy Thread
#9602
There's nothing worse than a loose back end!!
#9603
losi 22 esc question
Hi my name is jeff. Im new here so im not sure if there is a special place to post this stuff. lol. well my question is im goin to get a 22 buggy and am wondering if the deratrax de10 esc will fit with the rear motor set up. Im goin budget minded setup to get started. any info would be greatly appreciated. Thanks alot guys.
#9604
Im thinking about picking up a 22, but im kinda new to the whole 2wd buggys. For the 540 motors, the more turns it has the higher the kv? Please expalin to me the meaning of the turns.
thanks
thanks
#9605
The turns are the number of revolutions of wire that go around each poll of the stator. The lower the number of turns the larger the wire they can use and larger wire of shorter length has less resistance and thus produces more power.
#9606
No lower the turns the higher the KV rating. Just like old brushed motors. The lower the turns the faster the motor.
#9607
New to 2wd start at 17.5 boosted or 10.5.
#9609
About to place my wiring order with TQ. How short of a sensor wire do I need to order? Whats the distance from the back of motor to the ESC, running Rear motor?
#9611
Kinda depends where it plugs in on the ESC and which way the motor is turned. I measured mine at 100mm and it plugs in on the nearest side to the motor with the motor turned so the sensor wire plug is closest to the ESC. I'd say go with 120mm minimum just in case. 160 or 170 if you have to plug it in on the far side or have the motor turned with the plug further away.
#9615
