TLR 22 Racing Buggy Thread
#9512
I've ran my shocks with the gray o-rings for the past 6 weeks or so. I decided to switch to the black low-friction ones and was very impressed. Very smooth. I put them back on the car with the same oil, same spring, and same positions on the arm and tower........ The buggy was then 4mm higher!! I couldn't see what I did different and then I realized my other o rings were actually binding my shafts to the point they were affecting the rebound!
The rear suspension is so free now that it jumps all different. I guess I will have to learn to drive it a bit differently now. I broke an A-Arm in the rear because the buggy rocketed out of control over a jump the 2nd lap in thanks to that subtle change, lol.
#9513
I run on a pretty blown/loose out outdoor track in the summer months as well, hence the reason I came up with a loose track setup for everyone that runs on that sort of surface... The loose track setup that is posted on the TLR site is pretty much ON POINT (DIALED)for most conditions like you are speaking about but if you still feel you need to have the rear end locked in more. . . . Change the rear camberlink spacing... go 2mm inside and 1mm outside. .. that should help you out a lot.. rear camberlink height adjustment is really noticeable with this vehicle... Of course I am taking into account you are running the RIGHT TIRES which is 90% percent of setup Toy with that change to my existing loose track setup and let me know if it helped you out
#9522
With the normal one you can gear at max allowable and probably still get away with full timing advance on the speedo you got. With my tekin at full boost I was at 29/70 at the shootout. With the stock spur highest you can go is 34/76
#9525
Are you guys using traction compount on the track? curious if fuzz is getting in there or tire foam with traction compound or something maybe? Not an easy place to get that kind of stuff but that fuzz goes everywhere!
