TLR 22 Racing Buggy Thread
#9392
water
Dude, if u ever get your electronic soaked. Immediately disconnect battery and let it dry out completely!!! U may be able salvage your setup. I did with a venom setup. Mamba max TC drifted into a puddle, my dumb a$$ tries ti drive out. Ran over disconnected the battery. Then let it sit a couple of days after blow drying it.
It came back fo life.
#9393
Hmmmm....
#9397
at about the 40 second mark to 50 second mark your diff starts slipping. tighten it just a little bit to prevent more damage.
#9400
caster block?
I just bought a used 22 it has the 25 kick up block, how can I tell what caster block it has on it. I'm running on a small very hard tight dusty track, with small jumps. What caster block should I be using? It also has the 4.0 rear block. Thanks
#9403
pivot block
What will change going to the 3.0 or the 3.5 do? Sorry for the stupid questions
#9405
4.0 is the degree of toe-in, 0deg would allow wheels to be parallel to chassis centerline (roughly) As you get closer to 0 deg, the less toe'd in wheel gives less traction, improved steering. Going to a 3.0 unlocks the car a bit more than 3.5, 3.5 a bit more than 4.0. I run 3.5 (I'm a decent driver), pro guys (evans) is running 3.0 in the last set-up I saw.
