TLR 22 Racing Buggy Thread
#5176
Frank or Casper
On Dustin's setup sheet it says short lipo in forward position but on this forum we have been told 3 pads front 2 rear. Is there any chance he had his battery tray in the farther back position? I think with the tray in the rear position you would still get 2 battery foams behind the battery but the front would be against the battery tray? Is this right?
#5177
By the time you're done tinkering...the guy with the LRP already has more track time than you with an already dialed setup. Either way Im trying a speed passion esc just to see how it feels because I heard its pretty smooth, if it feels like a tekin its getn junked and Im droppin the LRP right back in. I just like the program card feature. I used to have a hobbywing esc and the program card is so easy to use. We'll see how it goes.
#5178
#5179
Track time is not a problem, I am a consistent driver and dont wreck. if the car is not set up for me to go fast i slow it down a little and drive the car, i dont just go as fast as i can even though it doesnt handle. I drive like I dont want to break and that usually gets me the win. Oh I race on carpet during the winter, so I guess thats kind of comparable to touring car, but really all escs can do just about the same. none is really an advantage over another, its a brand name thing I hated tekins until lrp took a month and a half to get a spx8 and motor back to me, then i went tekin... I was not a fan of the customer service.
I was never really a fan of losi either, and im still not, but i like the way my mid motor feels, and the way the big bores came stock.
Here is the buggy
Here is the buggy
#5180
I tried a mini battery and it worked quite well, I was surprised. The tiny battery weighed less so it gave me a little more umph than the saddle pack did. The only thing i had to change was putting traction compound on the tires, the rear end was a tad loose when I made the change. the hole in the window is to cool my esc, for some reason it was getting to be like 160, dropped significantly with the hole.
#5181
I finally got my body back from the painter! It looks sweet! I will get some pictures soon. I managed to route the wires and electronics very neatly. I found a perfect place for te on/off switch on the side of the ESC mount in the back (mounted to the chassis) It's easy to access. I think I'm going to buy myself a DX3R Pro to replace my old DX3.0 as well as a birthday present to myself! A $230 purchase is going to turn into a $600 here.
#5182
get us some pictures please. It's funny how that happens isn't it?
#5185
Here's a cheap option for wider hexes, I used these Traxxas ones to get a 1.62mm gain in width. The stockers are about 3.84-3.86mm wide. One the new hexes, I sanded down the little raised portion around where the pin goes, to make the back completely flat. At this width it was about 5.47mm wide, giving a nice 1.6mm gain.
#5187
#5188
I dont see an 82 either, but here are the losi spurs I found
http://www.amainhobbies.com/advanced...ilter_cat=1874
