TLR 22 Racing Buggy Thread
http://drivenproductions.net/content/store.php?s=store
With all this talk about steering racks i cant recommend there's enough. Its the only upgrade a 22 needs.
Run a new delrin rack/slider with a new housing, you will be $ ahead.
I think I'm gonna try that and the front tower.
What shock orings are most of you guys running?
Two low friction?
One low friction one grey?
Two stock grey orings?
Trackstar orings?
I have tried every combo and cannot get these shocks to stop leaking, also how often are most of you changing your shock oil and also changing the orings?
Thanks in advance for any replies
Two low friction?
Trackstar orings?
Two low friction?
Trackstar orings?
Two low friction?
Trackstar orings?
Works great and stops all the leaking.
Thanks again for your replies
Just figured I would share some pics of my current 22 buggy:
Running a Tekin RS with a Tekin 17.5 with a Spektrum Low Profile S6070 servo currently:
What battery strap is that?
Ikea ESC mount for mid motor You know those support mounts no one uses with their IKEA book shelves? Shoe goo mounted solid and low. Not cutting or fitting. I dremel sanded the top just to clean it off for servo tape and decals
Really? The Kyosho red oring? That's for a 3mm shaft the 22's shock shafts are 3.5mm I didn't think the Kyosho orings would work. So you are using the Kring on the bottom obviously, are you still using a 3mm limiter between the orings?
is the new 2.5 lrc ideal for carpet racing?
thanks alot
thanks alot
Ok, thank you very much for your help.
Suspended
Which setup are you southern californians running? I was pretty sure there was a Casper setup sheet which i followed to the T and I cant find it now. I wanted to double check it becaue I my buggy is pushing way to much off power so im looking for more steering.
I noticed Dustin Evans and Frank Root have new setups on the TLR site, just afraid its so different from the last setup i may have spend hours reconfiguring my buggy again.
