TLR 22 Racing Buggy Thread
Got to drive my 22 finally!
Very surprised at how easy it was to drive. Main issue I had was a lack of speed (Revtech 17.5T blinky 30/76 max endbell timing) and there was a switchback that was making me its bitch all day.
Borrowed the Revtech 17.5T from a friend and I'm pretty sure that I'm going to get a Revtech 13.5T or D3.5 13.5T. That and upgrade this slow ass JR servo to a Savox 1257TG and fill my gear diff with some 2000 oil.
Get the 70 spur and 33 to 35 pinion and it'll wake up.
Is 27/70 good for a 13.5?
I borrowed the Revtech 17.5T from a friend to see if I'd want to go 17.5T. Still think I'm going to get a 13.5T because I'd rather have to town it down than try to squeeze every drop of performance from a motor.
What tyres do people find good to use for indoor carpet racing?
Just picked up a 22! Has the following upgrades:
Currently it has a 3.5 Rear toe block installed, 25 brass kick up plate is included and 5 degree caster blocks. Buggy is set up very well for clay tracks and handles very well.
Carbide diff balls
Mid Motor parts (not shown but new in package)
25 Degree Brass kick up shim (new in package)
5 Degree Caster Blocks
Spare rear Yellow springs (white installed)
Threaded King Pins
Aluminum 3.5 degree LRC Block
.75 Rear Hexes
23T Aluminum Servo Horn (I will add the 23/24/25 plastic ones)
I shouldn't need anything else except maybe the BFast kit correct?
Also does anyone run saddles like shown here:
I have a bunch of saddles from my 4x4 that I would like to use. Also what is the max battery height?
Sorry for all the Questions lol, once I get acclimated with the buggy I'll answer more than i ask
Carbide diff balls
Threaded King Pins
.75 Rear Hexes
25mm would be a safe battery height.
Bfast kit was nice, but i had great success running a stock diff that i took my time building and breaking in.
What's the biggest pinion I can fit with the 76T spur gear. I've for three 76T spur gears extra and would like to use them if at all possible. Even if that means running a 37-39T pinion lol
shumacher mini pins in the rear, the new low pro cut stggers in the front. Run no foams and don't glue the front, and closed cell foams in the rear (you'll need to glue those though) Theres lots of set ups out there depending how much traction you have.
Rear motor, mine can go from 96 to 110 with the gears added together. So the max pinion is around a 34 with the 76 spur.
yea 35 is the largest but you have to do a little work get it in there...you would probably be better off with the 70/3x combo for NT, as for the 13.5 I am unsure best bet is to try the gearing and temp it after 5 minutes and also keep in mind of how it's performing
All of you asking for more gear must be forgetting that Tlr has a 70 tooth spur just for you all nt guys.
