TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 01-18-2011, 03:26 PM
  #1651
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Randy_Pike
Frank, I still have not received my car? What's up with that?
Me either.
And I thought we were dogs.
F N CUDA is offline
Old 01-18-2011, 03:28 PM
  #1652
STLNLST's Avatar
Trader Rating: 32 (100%+)
+1
STLNLST is offline
Old 01-18-2011, 04:32 PM
  #1653
rcguy76559's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Dyno Dan
A car's wheelbase and turning radius are not always directly related. The 22 is longer, but has more lock (angle of the front wheels at full travel to the left or right) than the XXX series and actually turns a tighter radius (curb radius). A 2wd with a super short wheelbase and only 35 degrees of lock will not turn a very tight turning radius. A longer car with say 42 degrees of steering lock can actually turn tighter with a smaller turning radius. This is all taking into account that that the front tires are not sliding on the track surface etc which is another story all together. The 22 has alot of natural steering built into it (insert boring geometry techno-babble here) and also has alot of wheel lock (wheel angle at full turn). The result is a very neutral, yet progressive steering feel. It is amazing how tight the car can turn, yet how neutral it is around center.
Thanks for the info that's what I was looking
rcguy76559 is offline
Old 01-18-2011, 07:31 PM
  #1654
ae-Dan's Avatar
Trader Rating: 39 (100%+)
tlr has a new ad in this months rc car action and it is bad a$$
ae-Dan is offline
Old 01-18-2011, 11:09 PM
  #1655
All my stuff is starting to come in. Today I got my front taper pin with JConcept molded foams (thought I'd give them a try, they seem really firm though so i have my doubts) Thursday i should be getting my rear bk bars and S6040 servo, and then Friday my saddle packs should be here for mid-motor setup. This is both torture and exciting.
Just one more month fella's (that is if the February release holds true)
dillydalley is offline
Old 01-19-2011, 05:10 AM
  #1656
wrightcs77's Avatar
Trader Rating: 551 (100%+)
Question on steering servos for this beast. I am looking at low profile servos, specifically the Savox 1251. Here are the specs.
Is this enough for 2wd buggy?
Speed @ 6.0V: .09
Speed @ 4.8V: .10
Torque @ 6.0V: 125 oz-in
Torque @ 4.8V: 96 oz-in
wrightcs77 is offline
Old 01-19-2011, 05:17 AM
  #1657
wrightcs77's Avatar
Another question. I plan on running this buggy on an outdoor 8th scale track. No racing, just fun track time for me. I have a Murffdog 13.5 and a Tekin 8.5. Should I keep both or just run 1? Which 1 to run if I only keep 1, is 8.5 too much for 2wd buggy?
Old 01-19-2011, 05:21 AM
  #1658
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
8.5 is what most guys in 2wd mod are running locally, some run a 9.5/10.5 as well......I will be running my twenty-two in stock buggy class with a NON-boosted 17.5.......I cant wait to build this car
Trevor Williams is offline
Old 01-19-2011, 05:34 AM
  #1659
Trader Rating: 36 (100%+)
According to Amain Hobbies the availability has been moved back to 25 March....
Jonathan Paulk is offline
Old 01-19-2011, 07:25 AM
  #1660
WilzFoto's Avatar
Originally Posted by ifuonlyknew
Also the receiver, side pods of the chassis and body, not to mention the chassis being made out of aluminum, and thus heavier and more dense than composite mass being centralized. In a vehicle that is not very heavy, relatively speaking, the centralization of mass, albeit even a slight amount, will have an effect on how easy it wants to change directions. Also you have to take into consideration how things scale up and down. For example if you take a real car and you move the rear hubs forward 0.3% of the wheelbase. It will change the weight distribution and wheelbase, but it probably won't make a noticable difference in handling. However if you move the rear hubs forward 1mm (which happens to be 0.3% of the wheelbase of my TRF201) on a 1/10th scale 2wd buggy, it drastically effects the handling of the car. This is what this thread and rctech should be, but alas we are stuck with "This is different it won't work" posts, and "Why does my Slash break if I drive it into a wall at full speed" threads, oh well. It would be interesting to take a CR chassis and cut the side pods off and see how much they weigh, then weigh the 22 chassis alone to see how much weight in just the chassis was centralized. Then ad that to the receiver and esc.
L O L.... i've been hoping that there were folks with more than 2-braincells posting-away on here. Glad someone understands mass-centralization and can post intelligently about it
WilzFoto is offline
Old 01-19-2011, 09:08 AM
  #1661
Horizon confirms by saying late March arrival. Well... maybe this will actually allow me to focus on finishing my bachelors degree this semester
Old 01-19-2011, 10:21 AM
  #1662
BrodieMan's Avatar
Yar, late March
Suppose the couple more pay cheques before it's release will allow me to buy more bling for it
BrodieMan is offline
Old 01-19-2011, 10:43 AM
  #1663
Krio's Avatar
Trader Rating: 159 (99%+)
At the same time you have to consider that the aluminum chassis now extends the full length of the car where lighter plastic used to exist, the servo is a half inch further forward, and the big bore shocks weigh noticeably more and are the furthest from the center. Until we get the car in our hands we won't know, but to me it looks more like a wash in that category.
I'm more inclined to see the increased steering coming from the higher pivot point on the front hubs producing a lower front roll center similar to 4wd buggies.
Krio is offline
Old 01-19-2011, 11:53 AM
  #1664
IndyHobbies.com's Avatar
Didn't want to look through 100 pages (on a vehicle that's not even out yet!) to find this out: Can I use a regular 5000mah, 40c lipo that I use in everything else, or do I need the special size lipos they show?
IndyHobbies.com is offline
Old 01-19-2011, 11:55 AM
  #1665
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Those special lipos are optional. They sure look good!
Dlewis4 is offline
