TLR 22 Racing Buggy Thread
Front--
Toe = 0
Ride Height = 24
Camber = -1
Caster = 5
Kick Angle = 25
Oil = 27.5w
Piston = 55
Spring= Red
Spindles = trailing
Shock limiters = 2mm
Shock locations = 1/middle
Bump Steer = 1.5mm
Rear--
Toe = 3.5
Anti Squat = 1
Roll center = LRC 3.5
Ride Height = 24mm
Camber = -1
Rear hub spacing = full foward, 4mm spacer behind hub.
Hex Width = +.75mm
Oil = 27.5wt
Piston = 55
Spring = Yellow
Shock limiters = 0
Camber link = 1/D
Shock Locations = 1/Inside
Battery Position = full forward.
Thanks for the suggestion, will try more squat at first. Change oil after. The slap is very noticeable coming down off big jumps. It creates a small amount of drag when it lands and sometimes breaks loose because of it.
Toe = 0
Ride Height = 24
Camber = -1
Caster = 5
Kick Angle = 25
Oil = 27.5w
Piston = 55
Spring= Red
Spindles = trailing
Bump Steer = 1.5mm
Rear--
Toe = 3.5
Anti Squat = 1
Ride Height = 24mm
Camber = -1
Hex Width = +.75mm
Oil = 27.5wt
Piston = 55
Spring = Yellow
Shock limiters = 0
Camber link = 1/D
IMO the black o-rings are a must, the stock o-rings cause too much drag.
Assuming you are using #55 pistons, I don't think 30-32.5wt is outside the usable dampening range for those pistons, especially in in higher temp conditions. I would try going up in oil before trying any geometry changes if you are having alot of chassis slaps and you believe the bottoming is having a negative affect on lap times.
More squat will also help some slapping issues, especially on jump faces. Try it and see if it makes you faster on the layout.
Front--
Toe = 0
Ride Height = 24
Camber = -1
Caster = 5
Kick Angle = 25
Oil = 27.5w
Piston = 55
Spring= Red
Spindles = trailing
Bump Steer = 1.5mm
Rear--
Toe = 3.5
Anti Squat = 1
Ride Height = 24mm
Camber = -1
Hex Width = +.75mm
Oil = 27.5wt
Piston = 55
Spring = Yellow
Shock limiters = 0
Camber link = 1/D
Toe = 0
Ride Height = 24
Camber = -1
Caster = 5
Kick Angle = 25
Oil = 27.5w
Piston = 55
Spring= Red
Spindles = trailing
Bump Steer = 1.5mm
Rear--
Toe = 3.5
Anti Squat = 1
Ride Height = 24mm
Camber = -1
Hex Width = +.75mm
Oil = 27.5wt
Piston = 55
Spring = Yellow
Shock limiters = 0
Camber link = 1/D
Oh, wow, i didnt even think of that. Its funny too, i just checked this on my SCTE last night after i installed the HA pivots. I will certainly give this a try.
Brian
Has anyone ran the new Pro-line black diamond shock shafts? They seem a lot better than the TiNitride shaft. Not sure if 33 bucks for a set of 2 is worth it..
Last edited by Matt M.; 07-03-2012 at 03:20 PM. Reason: i will post my sale items in the sale forums
I have them ordered through my LHS but they haven't arrived yet. If they last a full 4 months of racing then it will be break even with the TLR shock shafts as I have to typically replaced those once a month or at least before every large race if I want my shocks to be in top form.
i just rebuilt my shocks last week and they feel really smooth.. am i missing something? (and they don't leak)
Brian
Its funny, ill tell my GF all the time.....
NEVER......neglect the shaft.......
The loss of the coating creates a bit more friction than I like on the bench. My car just feels better with new shock shafts on it vs ones that look worn. I admit, it's probably just mental, as it drives me nuts to look at them worn out. I have shock shafts from my extra set of Triple-X shocks that I used on different cars for 3-4 seasons that look better than TLR22 shock shafts just after a week or two of racing.
No you are fine. The coating does not affect the performance of the shock at the level we are racing. Now if you are a factory driver maybe you can tell a difference. I have been racing for over 25 years I can promise you the shaft with some coating missing is fine. My 22 works great even with the silver gold shaft. Plus it saves some weight!
Brian
Brian
now im curious about getting new shafts (thanks guys)
LOL... now that was funny!
The bleeder shock caps definitely make the shocks rebuild quite simple. If you are looking to save some money you can consider LOSA5006.
http://www.horizonhobby.com/webapp/w...pe=productgrid
a couple of questions. what set up are most using now adays for a high bite indoor clay track?
has anyone upgraded bearings to ceramic? I was thinking about this and I couldn't find anything on it. there are acer and advantage. these cars are so responsive to the smallest thing I can only imagine a more free bearing can only help with acceleration, response and put less stress on motor and other parts.
thanks
thanks
