Associated Shocks
#16
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Always built shocks with 0 rebound. It's the only way to get each one consistent with each other, and rebound means there's excess pressure inside the shock which is what "helps" make caps blow off and such nasty things.
#17
I just rebuilt mine, but I think I'm gonna drop to lighter oil and bleed out the rebound. I'm just learning, and I'd rather learn to drive "clean and quiet". The track I usually run on is pretty technical, and it's way more important to be able to come out of a corner and set up than be able to fly through the air.
#20
Here is a tip for getting the same rebound other than none. Pick up the inner hing pin "snap on" spacers fot the TC5. Measure them up for the amount of rebound you want, snap them onto the shafts, push the shaft all the way in and tighten the bleed screw. Remove the spacers and you now have both shocks with the same rebound.
Bob O
Bob O
#21
This works best for ThunderbirdJunkie, so he will continue to do it
#22
Bob O
Bob O
#24
Anyone? What about bleeding out the air and excess oil like the manual says. It says to slowly bleed and then tighten the cap or bleeder screw while the shaft is fully compressed...does it need to push back out like the old associated shocks used to? because following the directions, this doesn't happen. What has been everyone's experience?
#25
Now, if you follow Associated's directions there would be no rebound. Associated tells you to fully compress the shaft and then tighten the cap or bleeder screw. If this is done the shaft will not come back out (rebound) on it's own. Is this how everyone does their shocks? Is there anyone from Associated who would like to respond to these questions? Calling Rick Hohwart!!
The AE shocks are designed so that the oil mixes with air inside the shock. Adding a bladder changes the design of the shock and when you introduce rebound it must be compensated for in the oil and spring. Rebound works like a stiffer spring.
All AE cars that use these shocks are designed with their use in mind. While adding bladder may seem easier, this will change how your car handles.
By using the bleeder caps, the shocks will be very consistent in terms of the amount of oil in each shock. In the past, bleeding the shocks was difficult and could require a few tries to make the left and right sides even.
If you choose to use some type of bladder, use the bleeder caps with no screw. This will release air behind the bladder which will will improve consistency and reduce rebound.
#26
This is exactly how you do it.
#28
I would like to thank everyone for their comments and insight to the topic, especially Rick for taking the time to explain how the shocks work. I have always purchased Associated cars and parts, when I wasn't dirt oval racing. To me, they are the best and now have excellent support. I will keep everyone posted on how the shocks perform.
#29
well Rick, I'm taking you're advice, pulled all the bladders out of my v2 shocks on my b4.1 and my sc10. going to give it a shot and see if my traction increases in my sc10, and my on power steering increases in my b4.1. it seemed like they both handled better when I wasn't running bladders. so wish me luck!! I bled all of the shocks the way you said, left maybe like 1/8th of an inch of rebound from the bottom of the lower shock seal cap to the top of the shock pivot eyelet. so, we'll see what happens. I have the day after thanksgiving off maybe I'll take a ride to my local track and give them a few runs each and see how I make out.
I have the original FT shocks without the lower cap. I purchased the bleeder caps and love them. I get a number of races on them before I service them and leaks are very slow or not noticed. I do not have any rebound. My SC10 handles great. So much so that people come up to me and comment how nice my truck handles. I have been able to increase rear forward traction and improve corner speed through spring/oil tuning, shock position and camber link length selections. Also Speedo settings can make a big difference too. I have a Novak Kinetic with 17.5 motor for the stock class and tuned the throttle curve, deadband, and throttle frequency to improve corner speed without sliding out.
So much goes into handling and traction and I don't want to have any shock inconsistancies. That is why I like the AE imulsion shocks.
#30
The main thing to remember with any shock is that they require constant maintenance. They are one of if not the most important part of a car's set up but are the most often overlooked. Many handling problems can be traced back to poorly maintained or problem shocks.
Silicone o-rings naturally degrade over time due to their contact interaction with silicone oil. They swell which increases friction with the shock shaft which leads to handling problems and inconsistencies. The o-rings in a car that sits unused for 3 months will be in nearly as bad a shape as those in a car that is used once a week for that same time period.
Shocks also naturally lose some oil when used so they need to be filled occasionally. Some racers might completely rebuild their shocks before each big race. Some will rebuild their shocks before qualifying and then again before the main. For club racing this is too often but it is important to plan a maintenance routine and stick with it.
