B44.1 Thread
#2611
here is some closeups. notice thread length and your window of adjustment on height of pack. fyi i have another b44.1 fully modded for sale if your interested. prob well over $700 invested.
#2612
#2614
Space the dogbone in rear further inward, the little axle spacers that normally go on last before you put the pin in the axle...put them on first before sliding the dogbone into the hub (i have 2-3 axle shims on the inside). The aluminum center bulkhead also helps to reduce alot of the chassis flex in the rear. As far as the front, ive never had any problems there, maybe double check your front shock setup and see how many limiters you are running.
#2615
#2616
No problem, this is the center aluminum bulkhead:
http://www.amainhobbies.com/product_...r-Bulkhead-B44
flex the car from the rear with the plastic one and then put this on, you will be amazed at how much it flexes with plastic.
#2619
What I do is instead of using the set screws that go into the blue post for the blue thumb screws that hold the battery straps down, I put a long 4/40 screw through the top of the thumb screw it self and I can run any size packs, plus I have fat fingers so I can use my hex driver to take the thumb screws on and off, much easier for me and works great.
#2620
Thanks from the looks of it it may just fit? The 6000 pack is 32mm with the connector I would guess I need at least 36mm to clear it. Any know what the measurement is from the chassis to the bottom of the top plate?
#2624
#2625
1Likes
