Like Tree1Likes
B44.1 Thread
Old 05-24-2012 | 09:03 AM
  #2221
TJMac's Avatar
Originally Posted by Finrod
Thanks for the reply. What exactly would be the effect of a damaged or missized crush tube?
The crush tube goes between the two bearings in the rear hub. When you tighten down the wheel, the crush tube's job is to place all the pressure on the inner race of the bearings only. If the crush tube is damaged/missing/too short, you're putting that pressure on the entire bearing which is bad. If the tube is installed correctly and not damaged, you should be able to absolutely crank down on the lock nut and your wheel should still spin/move freely with no binding. If the wheel becomes harder to spin/move the tighter you crank, there is a problem.
TJMac is offline
Old 05-24-2012 | 09:28 AM
  #2222
Originally Posted by TJMac
The crush tube goes between the two bearings in the rear hub. When you tighten down the wheel, the crush tube's job is to place all the pressure on the inner race of the bearings only. If the crush dube is damaged/missing/too short, you're putting that pressure on the entire bearing which is bad. If the tube is installed correctly and not damaged, you should be able to absolutely crank down on the lock nut and your wheel should still spin/move freely with no binding. If the wheel becomes harder to spin/move the tighter you crank, there is a problem.
Thanks, that reply was very informative! =)
Finrod is offline
Old 05-24-2012 | 09:34 AM
  #2223
79kmc's Avatar
Originally Posted by vw addict
Hey all, new to the B44.1, just got my used one yesterday. Anything I should worry about right off the bat? I need to mount up some rubber, put the electrics in, paint up the body, and figure out the wiring on these pesky new saddle packs.....
If i were you i would pull the diff's apart and make sure they are shimmed correctly and there's no side to side movement cause you will only strip gears if you don't shim them out
79kmc is offline
Old 05-24-2012 | 11:14 AM
  #2224
can you elaborate? Side to side movement of the gears themselves or the outdrives? Does this thing have gear diffs kinda like my SC10RS? Sorry I am clueless, I just got it yesterday and haven't even really looked at it yet.
vw addict is offline
Old 05-24-2012 | 04:00 PM
  #2225
To ballast weight or not to ballast weight? And why?
zipperfoot is offline
Old 05-24-2012 | 04:24 PM
  #2226
t0p_sh0tta's Avatar
Depends on how tail happy the rear is, and how rough the track is (it's also really dependent on the battery you run).
t0p_sh0tta is offline
Old 05-24-2012 | 05:07 PM
  #2227
leggoman's Avatar
As it is a ball diff, there are only really two gears. the pinion and the bevel. The outdrives and the bevel gear are all part of one shaft. This needs to be shimmed across so the bevel gear sit snugly against the pinion. At the front im using 7 shims on the left between the bearing and the bevel and 2shims on the right. They all seem to vary. You should also check the pinion shaft for end to end movement and add shims if necc.
Hope this helps.
Brett.
leggoman is offline
Old 05-24-2012 | 05:33 PM
  #2228
Originally Posted by leggoman
Hope this helps.
it does, a ton, I'm still learning everyday. I think I have too many different cars to service, am I getting rid of any, NO.
Old 05-24-2012 | 07:26 PM
  #2229
Suspended
A fresh new kit I built 3 nights ago to replace my old 44.1. The avid springs are great and I cant wait to try them on this and my b4.1 Hey guys what's the likely hood of avid making a steering rack just like the b4 but for this?
CT RACER is offline
Old 05-24-2012 | 07:54 PM
  #2230
ray_munday's Avatar
Generally I would suggest to run the ballast weight unless your track is a) smooth and b) flowing (no tight corners).
Weight in: rear is more settled on bumps, there is more low speed rotation, but rear does bottom out more off large jumps
Weight out: rear bounces more on bumps (especially off power into a corner), there is less low speed rotation (but tends to be very smooth in sweeping corners), less bottoming off jumps. Without ballast weight, run 2.5-5wt lighter rear oil.
Battery weights vary a lot, but I like it with ballast + cells around 370g. With the reedy packs which are heavier (~330g) some run a smaller weight between the cells.
Personally I find the ballast helps to make the car faster but a little more edgy to drive in the corners as it has more of a 'pendulum' effect.
Ray
ray_munday is offline
Old 05-24-2012 | 10:27 PM
  #2231
The reason i ask is because i could install the weight and then tune the car around it. It all depends on whether the weight is a standard and required tuning option. I run the Reedy 5200 pack. My home track is SRS, (Cactus track). Rear end was ok, but my tuning was way off the first time out this last weekend. I was running losi big bores but the wrong rates. Too soft.
So before i start messing with spring rates and oil, i wanted to know if the ballast weight was a standard tuning option that everyone uses. Sort of like the rear sway bar.
Old 05-25-2012 | 05:12 AM
  #2232
t0p_sh0tta's Avatar
Honestly, I just drive it. I use my tires to tune.
Old 05-25-2012 | 08:16 AM
  #2233
mjk1210's Avatar
I may be wrong, but I'm pretty sure most all the sponsored guys run the ballast. It plants the rear end better on acceleration and gets more consistent rotation of the rear end around turns. At least, that's what I feel with it.
mjk1210 is offline
Old 05-25-2012 | 04:18 PM
  #2234
Wrong section!
Huck50 is offline
Old 05-25-2012 | 07:33 PM
  #2235
Originally Posted by Huck50
Wrong section!
I think he was talking about the car
