Like Tree1Likes
B44.1 Thread
Old 05-23-2012 | 02:45 PM
  #2206
Hi guys,
I'm experiencing some problems with my back wheels. Either my screw nut tends to loosen while I drive or when i fasten it harder it somehow blocks my wheel partially. I don't know how exactly I can fix this. It is quite annoying, as it has destroyed two wheels already..
Has anybody of you had the same issue? Do you know any method to fix this?
Cheerz
Finrod is offline
Old 05-23-2012 | 03:24 PM
  #2207
fastchvy's Avatar
Originally Posted by Finrod
Hi guys,
Cheerz
Run the rear hex adapters and some new nutts, it will fix your problems
fastchvy is offline
Old 05-23-2012 | 03:30 PM
  #2208
TJMac's Avatar
I'd also make sure the crush tube isn't damaged and/or the correct size.
TJMac is offline
Old 05-23-2012 | 04:15 PM
  #2209
fastchvy's Avatar
Guys, i have a 3 run old reedy 6.5 for sale...not even a week old..im looking for 70.00 shipped to the lower 48 states..
fastchvy is offline
Old 05-23-2012 | 05:05 PM
  #2210
dspoo2's Avatar
Originally Posted by 79kmc
That looks sweet i'm going to have to get some,also what body is that
stock b44 body
dspoo2 is offline
Old 05-23-2012 | 06:12 PM
  #2211
mrplease's Avatar
thats the original b44 body. never been crazy about the b44.1 or any of the new cab forward bodies...
mrplease is offline
Old 05-23-2012 | 10:01 PM
  #2212
IRM616's Avatar
So I'm adding weight to my b44 like the b44.1 but it doesn't fit. It's hitting the rear shaft. Help.ballast weight that it. Thanks
IRM616 is offline
Old 05-23-2012 | 10:08 PM
  #2213
I dont even use the ballest weight, it causes it to jump weird
rickybobbyxxx is offline
Old 05-24-2012 | 05:10 AM
  #2214
t0p_sh0tta's Avatar
I used tape weights, stuck to the insides of the lipos.
t0p_sh0tta is offline
Old 05-24-2012 | 07:20 AM
  #2215
Hey all, new to the B44.1, just got my used one yesterday. Anything I should worry about right off the bat? I need to mount up some rubber, put the electrics in, paint up the body, and figure out the wiring on these pesky new saddle packs.....
vw addict is offline
Old 05-24-2012 | 07:39 AM
  #2216
t0p_sh0tta's Avatar
The stock setup is great, and it's pretty much bulletproof as long as you aren't bouncing off stuff.
Keep it off the pipe, and don't overdrive it just because it's 4WD. Do everything you can to stay smooth, and follow the fast line.
Coming from 2WD, you have to really focus on braking before the turn. That's the biggest hurdle for me.
Old 05-24-2012 | 07:46 AM
  #2217
I've been wanting to try out EP 1/10 4WD Buggy..and the B44.1 seems to be a very popular car in this class..Just wondering,does the buggy comes with big bore shocks?if it doesn't,is the buggy good enough with the standard shocks?
tq23 is offline
Old 05-24-2012 | 07:51 AM
  #2218
t0p_sh0tta's Avatar
It doesn't and it's great.
Old 05-24-2012 | 07:53 AM
  #2219
thanks!is there any building tips or recommended option parts that i need to know of?
tq23 is offline
Old 05-24-2012 | 08:00 AM
  #2220
Thanks for the reply. What exactly would be the effect of a damaged or missized crush tube?
Finrod is offline
