TAMIYA TRF502X Thread
#571
#572
Does anybody have a clue where I can get diff outdrives for my 502x or a successful painless gear diff swap? The drive line on mine is trashed and I've sunk so much into it, I can't see just letting it sit around and go to waste. I need all new outdrives and drive shafts. Thanks in advance. The drive shafts I have located, but am really struggling with the rest.
#575
http://www.tqrcracing.com/shop/produ....asp?p_id=4109
But there is only one set left in stock.. so better act quickly TQ hobbies is pretty good for getting all of the parts for the 502x..
BTW where did you find the Team C Diffs at?? they are out of stock everywhere
#576
I believe these are the ones. Only $80 as well.
http://www.tcmodels.net/index.php?pa...hk=1&Itemid=71
Thanks for the link. Bummer they only have one. I need front and rear.
#577
#580
http://www.tcmodels.net/index.php?pa...mart&Itemid=71
and I highly suggest that you get these outdrives as well
and also get a complete set of drive shafts front the Tm4 for the 502x..
#582
Bezerk RC TRF502xs Upgrade chassis set..
Features
3mm milled pockets, narrower and 3.5mm longer lower chassis with flat bottom
4mm revised shock towers
2.5mm revised upper decks
Floating servo mount system from the 503 that has been brought over and is reversible
Adjustable battery strap with the ability to move the battery for optimum balance
15gram brass balance weight
Features
