Difference between inboard and outboard toe-in >
Old 08-12-2010, 07:51 PM
Kent Beal's Avatar
Trader Rating: 66 (100%+)
Default Difference between inboard and outboard toe-in
With the release of ASC T4.1 and the B4.1, I noticed in the instruction manual that they put 3deg toe-in at the inner hinge pins and 1/2deg on the rear hubs? Most people who have the older vehicals just get toe'd-in rear hubs.
Can any explain the difference between using toe-in on the in-board vs using it out-board?? what the benefits would be in each?
Kent Beal is offline
Old 08-12-2010, 08:07 PM
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Inboard toe changes affect the wheelbase.
t0p_sh0tta is offline
Old 08-14-2010, 12:47 PM
Kent Beal's Avatar
anyone else
Old 08-14-2010, 07:55 PM
CCristo's Avatar
Trader Rating: 56 (100%+)
From the B4/T4 thread...
Originally Posted by DanGriffin View Post
Changing the toe block changes the inboard toe. Increasing inboard toe in general provides more overall traction and makes the car more mechanically stiff. The downside of inboard toe is it can decrease cornerspeed.
Changing the outboard toe (hub carriers) is generally a mechanically softer change, and would be better suited for lots of sweeping corners. It also feels like a more subtle change.
The toe blocks also change the wheelbase of the car more than the hubs.
CCristo is offline
Old 08-14-2010, 10:57 PM
And again .......Exactly what he posted
gottabaja is offline
Old 08-15-2010, 04:14 PM
Kent Beal's Avatar
Thanks Chris for an anwser that was longer and better than six words.
Old 08-15-2010, 05:25 PM
What else can I say he nailed it the first time. Unless you need to read it again.
