RC10B4.1 FT/WC
Old 01-18-2011 | 08:08 AM
  #1336
kyle3333's Avatar
Originally Posted by mrjeremyaaron
I just finished putting together my new ft b4.1 but dont' know how to set the ride height and camber up.. any suggestions welcome!
Obviously you want the car ready for the track, so have the battery pack in, tires on, etc. Set the ride height first, as this dictates the camber of the wheels. It depends on your track, but a typical ride height would be 24mm to 25mm both front and rear. If you don't have a ride height gauge, make the front arms level and the dog bones in the rear level, this should be a good starting point. Ride height adjustments are made by moving the shock collars up or down. Make sure you drop the car at from at least 6" in the air, before you make any adjustments. Every time you make an adjustment drop the car again to see where you are at.
With the ride height set, use either the included camber gauge or the RPM camber gauge to set the camber. Again, it depends on your track, but a good starting point would be -1* of camber all the way around. Just like setting the ride height you will want to lift the car at least 6" and drop it in between adjustments. I turn the radio and the car on for camber adjustments to keep the front wheels straight.
Hope this helps.
kyle3333 is offline
Old 01-18-2011 | 08:11 AM
  #1337
mxracer458's Avatar
So with a non boosted setting it looks like everyone running a 72 spur
mxracer458 is offline
Old 01-18-2011 | 08:39 AM
  #1338
TfnG's Avatar
My local indoor clay track does not allow boost in any stock classes. I'm running 69/33(b4.1) and still coming off at no more that 105 degrees. Doing this with a Ballistic motor and Tekin in blinky mode.
2 weeks ago the announcer was calling me out in first round saying I prolly had it boosted...until after the round I showed him the blinks. So I'd say my setup is pretty fast.
TfnG is offline
Old 01-18-2011 | 08:55 AM
  #1339
Where did you get a 69t spur?
Chris Gierse is offline
Old 01-18-2011 | 09:13 AM
  #1340
TfnG's Avatar
A Main a few months back.
TfnG is offline
Old 01-18-2011 | 09:14 AM
  #1341
CCristo's Avatar
R/C Tech Elite Member
Kimbrough makes the 69t spur. Part # 302
CCristo is offline
Old 01-18-2011 | 09:22 AM
  #1342
I will have to check that out. I assume the teeth barely get past the slipper pads.
Old 01-18-2011 | 10:12 AM
  #1343
DaveW's Avatar
You always want a little bit of play for free movement. The shock will bind if the upper nut is too tight, or the nut or a washer hits the shock cap through the shocks range of motion.
DaveW is offline
Old 01-18-2011 | 10:49 AM
  #1344
jordan23junkee's Avatar
Ok, today I tested a 72 /30 with an epic duo2 17.5
I first notice smoother ,quicker acceleration out of the turns. I then preceded to try the jumps and I probably almost doubled my hangtime!lol I felt as if the car finally came alive and handled my backyard track with more precision. I think I found my combo. Totally different car.........The balance even slightly improved. I felt more stable on and off the jumps...
jordan23junkee is offline
Old 01-18-2011 | 11:07 AM
  #1345
RA99GT's Avatar
i used to run around 75/27 in truck and 69:39 in buggy, with max timing on a duo2 motor back in the no boost days... i'd adjust the pinion size up/down to keep motor temps near 160-170F.
RA99GT is offline
Old 01-18-2011 | 11:26 AM
  #1346
Default T4.1 Paul Wynn Setup
Anyone running the Paul Wynn setup? I am running the Cav setup on my T4.1 with pretty good success, but am curious about Wynn's.
Badazz45 is offline
Old 01-18-2011 | 02:41 PM
  #1347
mrjeremyaaron's Avatar
Hope this helps.
AWESOME - a big help thanks Kyle! Got my first buggy race this weekend (apparently these things handle a bit different to the T4) so wanting to get some practice in before then..
mrjeremyaaron is offline
Old 01-18-2011 | 03:17 PM
  #1348
justicepool's Avatar
Default T4 body on T4.1?
Will it fit a T4.1?
If anyone has a nice painted T4.1 body for sale let me know.
Thanks,
John
justicepool is offline
Old 01-18-2011 | 03:25 PM
  #1349
i1justin's Avatar
Bodies Are the same t4->t4.1 and B4-> B4.1 the only one that actually changed chassis shape is the B44.1
i1justin is offline
Old 01-18-2011 | 03:28 PM
  #1350
Armaan's Avatar
Originally Posted by justicepool
Will it fit a T4.1?
Thanks,
John
Member RayDog has one for sale.
Armaan is offline
