RC10B4.1 FT/WC
#9901
You can search the thread and find a lot of different gearing set ups.
I am at 75/33 as of now with 45* of timing on my TP motor. It's at about 150f after 15 minutes, and during a 6 minute qualifiers and mains it gets to 115f(+ or - a small amount). It feels the most consistent thoughout the time I am racing.
#9904
Super Moderator
Trader Rating: 31 (100%+)
Anywhere from 72/32-35 will be the norm you will find. She's gonna be a dog at 75/26
#9906
I had alot of gearing issues trying to figure out a 13.5. Finally figured out that the Factory Team manual is wrong. It has the right FDR but the wrong pinion for 17.5 and 13.5. So grab the FDR number from the manual and figure out what you need to be close to it. Base it off a 75 spur (so you can use big pinions). You SHOULD be in the 32-35 range if I remember correctly.
in case you forgot, calculate FDR by doing : Spur / Pinion and then X 2.6 (our trasmission gear ratio) So for example 75 / 35 = 2.14 2.14 x 2.6 = 5.564 FDR
#9907
I am at a 30/75 and it moves well. I may try a 28 for the track I race at due to it's size. (Very small)
#9909
Losi Big Bore Springs for B44
Sorry to post this qestion here, but the B44 thread is kind of dead. Does anyone know what losi Big bore spring are being used on B44?
#9910
#9912
#9913
Anyone have a good setup for out door, blue groove clay? Slightly dusty at times.
Ive been using JR Mitch's setup from my track (Region 4 Roar Nats) and, while its a great setup, i get a awful lot of slap.. However, i really like the setup which makes it hard...
Been using this setup. I did tweak it a tad to my liking, went with a softer spring in front and 1 less bump spacer in my front camber link.
THinking of trying this one.
