RC10B4.1 FT/WC
#8559
Hey all,
I'm running 30f and 25r oil in shocks, with brown f and green r springs...
Our track is pretty bumpy but also very fast (Its more designed for 8th scale)
I'm thinking of trying lighter oil to soak up the bumps... What will it do to the handling? I'm thinking more weight transfer which will mean more steering entering a corner under breaks and less coming out of the corner as the car squats down... Does this sound right?
Just curious so I can begin to alter the setup
Phill
Phill
#8562
I am using Losi cups and rpm retainers at the top. Not sure why they are longer than the silvers, at least in my case. Either way, I like the Losi springs alot, more forgiving but they still have great turn in.
#8563
Yeah noticed the same thing, have tlr reds up front and pink rears. All collars are fully up and just makes ride height of 24mm front and back. Not sure how everyone is getting any more range to run lower. Anyone have a close up pic and maybe someone running red fronts or even orange fronts? I have the rpm upper pressed on the the AE upper collars so I know there is no more room there for it. Would like a little more adjustment room.
#8564
What Losi springs? The black TLR 22 springs with the color on the end? Or are they the colored springs? I noticed a difference as well. When I tried the colored springs I couldn't adjust much, then I got the new TLR 22 springs and they are much better.
#8565
Its the tlr 22 springs that are black, seems the softer springs like red barely fit and just at 24mm. In rear even pinks are at top to get 24mm ride height. Anyone changing the ball end to lower the spring or maybe doing the rpm collar differently on the AE threaded collar?
