RC10B4.1 FT/WC
#8493
You make it fit , suggest a JConcept Finisher its designed for the 8m..
#8495
Nice video from Trackside, but I have a question. I am in the process of switching mine over to the new chassis and was wondering if plastic parts are still being used on tracks with less grip. I see most people are using the carbon parts but the track I race at I would consider a slick track that gets watered between every round. Usually a little cold out on the track as well. Silt dirt with very little clay. Racing line is generally clean and usually a little damp. What should I try first?
Suggest using the graphite nose plate & ft arms , makes the car more consistent and easier to drive fast .
Most use graphite rear arms as well , but some also use plastic if more traction is desired...
#8500
Is anybody using the rpm long shank rod ends? I have seen a car using both long and short rod ends, but i can't recall if it was longs-inner and shorts-outer or the opposite.
#8501
AE +8mm ..
Thiught I'd Share the Finnisheron the Buggy ,and My New T4.1 Punisher Body !
#8502
Little better View ..
#8503
Front view..
#8505
There is one body that doesn't fit, the AE B4.1 body. Not the one you get in the FT kit, but the one you get with the RTR (you can also get it clear). That body doesn't fit at all.
