RC10B4.1 FT/WC
#467
#468
I am looking for the graphite steering rack. Anyone know if they still make/sell it. The current plastic rack seems to have alot more flex. Which may not be noticable on dirt but when on carpet it is.
It used to be the Factory team steering rack, I can't seem to find it.
#469
Three quick questions...
How much toe-in/out should I start with on the B4.1?
Best way to measure it? Measure front of tires then back of tires?
Front Wheel shims? There is some play in my wheels and it looks as if they could use a shim or two on the axle before installing the wheels.
What size shim should I get?
- Jake
- Jake
#470
Willing to Learn!
Sup guys, new to rctech as well as new to 1/10 buggy racing. Just picked up my first buggy a b4.1 brushless rtr with onyx 230 charger and smc 4100 lipo. I was going to with the FT but I wanted to race this past friday. Came in Third for the Sportsman class. Not bad for my rookie debut. Everybody at my local track is very knowledgeable and helpful it's actually really cool. They're all helping me with set ups and driving tips etc..
Anyway, I'm super excited for the winter season I can't wait to practice and learn my car and race in the upcoming months. SO my question is what am I missing? I've been reading and talking to people A LOT but I want to be prepared. Not just for my buggy, is there anything else you guys think I need for my pit bag and other stuff?
I got a airtronics mg servo, cvds, tires, motor spray, ca glue, and a container to clean my tires from the guys at the track.
All this stuff I got at tower:
DuraTrax Pit Tech Deluxe Car Stand Blue
RPM Small Parts Tray Magnet
Integy Ti-Nitride Hex Wrench Set (6)
Associated Ball Cup Dust Cover (28)
Associated Factory Team 4-40 Aluminum Locknut (6)
Associated Factory Team Aluminum Locknuts 8-32 (6)
Associated Silicone Shock Oil 30 Weight 2 oz
Woodworks LiPoSack 9x12"
Associated Silicone Shock Oil 35 Weight 2 oz
Associated Body Clips Metallic Blue Short (6)
Associated Universal Roll Pin T2 (4)
Associated Rear Wheel White RC10B4 (2)
Associated Front Wheel White RC10B4 (2)
Associated Caster Block 30 Degree Left & Right RC10B4
SMC LiPo 7.4V 4100mAh 24C Hard Case Deans
Associated Factory Team Aluminum Turnbuckle Wrench
Integy Tip 4-40 Wrench 0.05
Associated E-Clips 1/8 Shaft (12)
Associated Front A-Arm RC10B4 (2)
Associated Factory Team V2 1/10 Shock Rebuild (4)
Associated Rear A-Arm RC10B4 (2)
Associated Adjustable Servo Link RC10B2
Associated Hinge Pin Set RC10B4
$30 Promotional Discount
Associated Factory Team V2 .89 Threaded Shocks
Associated Factory Team V2 1.18 Threaded Shocks
Associated Factory Team Titanium Turnbuckle Kit Blue B4
Associated MIP CVD Set RC10B4
Associated Kimbrough Spur Gear 78T
Associated FT Hinge Pin Brace w/Hinge Pins B4/T4/SC10
JConcepts Illuzion Hi-Flow Clear Body RC10B4
Associated Decal Sheet RC10B4 Logo
Associated Factory Team Truck/Buggy Rear Spring Kit(10)
Associated Factory Team Buggy Front Spring Kit (8)
Associated Factory Team Locking Adhesive
Associated Universal Shim T2 (14)
Kimbrough Slipper Gear 48P 74T B4/T4/SC10
RPM Gear Cover Black B4/T4
RPM Long Shank Rod Ends (12)
(Only reason I got all this stuff was the "Bill Me Later" option )
Next paycheck I'll work on a Radio, ESC and Motor.
#471
#472
Super Moderator
Trader Rating: 31 (100%+)
I disagree, FT T4 and B4's had all Graphite (composite) parts including the steering rack. Unless you mean like actual laminated graphite, then no.
#473
The steering rack was never carbon composite. The FT kits just included carbon composite towers and arms, front top plate and rear mount and the early versions had the chassis as well. The caster blocks, steering knuckles, rear hubs, and steering racks were still the plastic composite.
#474
Anyways, I wish they still made them.
#475
It looks like you picked up some great upgrades. My only advice is similar to the advice I give to new photographers: much like focusing your investment on lenses vs camera bodies and accessories, you'll get more for your money by picking up good electronics (servo, Tx/Rx, motor, ESC, batteries) than you will with hop-up parts. Hop-ups can be really useful, especially on certain critical areas that are under more stress, but they are also the highest-margin products that the RC vendors sell. If you continue to get more in to RC you will find yourself picking up new kits regularly and moving electronics from one kit to the next. If you decide to switch to a Cougar SV, for example, those V2 threaded shocks will be useless. That said, I also bought them for my SC10. ;-)
#476
Welcome! You picked a great kit to get started with. Just be careful because this hobby can become a huge money pit if you don't pace yourself.
Next paycheck I'm going to pay off the parts from Bill Me Later then pick up the M11. Paycheck after that I'll pay off the M11 and get esc and motor. I'm pretty much set after I pay off the esc and motor.
The only thing I believe that is left besides PRACTICE is a quality bag to hold all this stuff. Any suggestions?
#477
