RC10B4.1 FT/WC
Too bad that picture was with a Kyosho car
Has anyone tried the Hot bodies beams (pink or red compound) on the rear? Used them on SCT front and rear and they were probably the best tire I've used IMO on the track I run on (smooth with low to medium traction and slightly dusty)
Just wanted to see if anyone else had any experience with them?
Also have you or anyone else tried the fullslot front tires (supposedly the tires to use with the beams rear). They both look awesome.
Thanks!
Anybody know a good spot to start with mode settings on lrp sxx v2 with reedy 13.5. It stock default setting is 0-3-3-0. Gearing is at 72/30 and going to play with engine timing tomorrow between 30 and 40 degrees. Don't know really what to do with mode 2,3 and 4, any help appreciated. Especially interested in feedback on drag brake mode 4.
What is that car on the Ae website? News about this Patrick Hofer.
It says that Patrick placed his B4.2 on TQ and his B44.2 on second.
Typo or what the heck?
R/C Tech Elite Member
The picture of the car with Patrick is mid motor...
Typeo with and xfactory car imo
Pink HB Beams
I run beams too and the only thing i don't like about them is that hot bodies tires seem slightly bigger than any other tire. If you are using a open cell in the rear it will be fine since it fills the whole tire, but if you are using a closed cell, the tire is very baggy. I don't know if that is a bad thing, but it doesn't seem like it should be that way.
I use pink beams on a loose clay track that has low grip with bomb one open cells foams and i also use pink beams sanded down to slicks with aka cc foams for the high bite clay track that i go to. I bought some JC tires to sand down to try but hot bodies pink compound is very soft and does work.
Please take a look at this from the Oople forum:
http://www.oople.com/forums/showthre...=118344&page=3
It looks to be a B4.1 with a Vega Gen 2 conversion.
Personally I think the next AE mid motor car will be based on the CML Centro C4.1 mid motor conversion, but with composite plastic chassis, rather than aluminium.
I guess the AE news release was a typo, or a hype builder?
Big races in the UK this last weekend saw UK AE drivers all using the C4.1 as is normal over here.
I would prefer that AE just make a conversion kit and leave the b4 alone. I really do not want AE dinking with the AE chassis.
But the B4.1 platform is uncompetitive on the UK/Euro style high grip carpet and astro turf tracks. All the other 2wd platforms offer mid/rear options, just look at the new yokomo.
A racer at my track suggested this conversion to the rear shocks on the B4.1.
We used Traxxas Slash #3768 Spring Retainers/Head Set and then Losi Springs. The ones my hobby shop had were #LOSA5129, 2" Spring, 2.9 Rate Orange. The result is show below. The Slash spacers work too in order to adjust firmness (see second photo).
Feedback? Others doing this too? Seems to work OK and there's no rubbing at all.
yeah, a conversion for the euro guys and the normal chassis for the US. I do not believe a combo car would be better than a conversion. To satisfy everyone, it would need to be just as good or better than the Conversion kits (xfactory/c4.1) and just or good or better than the current rear motor for the US. I wont say it is impossible, but I think it is unlikely that anyone can make a convertible car that is better on both types of config. One of the configurations would be an after thought. Mostly likely with AE the Mid motor would be an after thought. The win worlds with the rear motor config. So why would their main focus be mid motor? Again, AE making a conversion kit would be better probably for all parties.
Tech Legend
Anyway, the car was also setup with some HB beams in the rear and fullslots up front, pink compound I believe for both or maybe softer.
with this setup, the tires hooked up great. very controllable, quick change of direction. I did have one mishap where the screw sheered off on the shock to a-arm mount, so I had to move my shocks to the outer a-arm position and to be honest, the car actually felt a bit better.
The only thing I noticed that I may work on a bit more was that I could get the rear to step out off throttle easier than I like, but, other than that it was excellent. Loads of steering.
Also used Sticky kicks blanco compound and it really hooks up on carpet.
For electronics, I use:
- Speed Passion GT2.1 with latest mod software
- Speed Passion V3.0 Competition 8.5 motor
- JR 9100S servo
- Futaba antenna-less receiver with 4PL radio
Very happy with this setup, motor runs cool, and is very smooth. Same with ESC.
I got a box full of barcode-ish tires to try from various manufacturers, will report back next time I get to run on what works better but I think the tread patterns are great for carpet. I will also try some scrubs that came with too for the fronts.
You only need the upper retainers which will slide right onto the threaded adjuster and the bottom spring cup. Then you have to buy losi 22 springs or the avid or what I highly recommend are the new ae BB springs. I'd also just get a set of the ae BB spring cups too, much better fit than the TRX ones.
