RC10B4.1 FT/WC
Old 12-06-2012 | 06:56 PM
  #25246
idrummerboy13's Avatar
Originally Posted by YankeeFan123
Maybe its different because he's running the reds not pinks.
I personally don't know the difference as I never ran Losi pistons
Idk about pinks, I run on a pretty big indoor track but not to huge, jumps are not to big but even layouts with big jumps these work better. More pack it makes my car feel forgiving and lands better.
idrummerboy13 is offline
Old 12-06-2012 | 07:03 PM
  #25247
Has anyone run the new speed passion reventon pro esc for mod or stock? Curious on your opinion. I've run the gt 2.0 pro and was very happy with it.
slater333 is offline
Old 12-06-2012 | 07:09 PM
  #25248
Matt Trimmings's Avatar
Red...Pink....its all the same, just depends on what color you think they are. Losi doesnt make a pink piston.
Matt Trimmings is offline
Old 12-06-2012 | 07:11 PM
  #25249
rimracker's Avatar
Originally Posted by Matt Trimmings
The new MIP topshaft or the old one? My new one has been quiet since I put it in. It is the one that looks hard anodized.
+1
rimracker is offline
Old 12-06-2012 | 07:52 PM
  #25250
3srcracing's Avatar
Seems my question got missed in all of this mess haha...
Is the jconcept axles any beneficial over the stock ones if you aren't running hexes?
3srcracing is offline
Old 12-06-2012 | 08:01 PM
  #25251
They should be stronger than the stock hex axles and seem to mount a little better, you dont have to worry about the little c clip with the JC axles.
Old 12-06-2012 | 08:55 PM
  #25252
Tradin Paint's Avatar
The JC axles are only to be used with hexes. If you are not running hexes then you are best to stay with what you got
BTW - Get out of the ice age. The hexes are like 12 months old
Tradin Paint is offline
Old 12-06-2012 | 09:03 PM
  #25253
kdub's Avatar
About the Triad spur gear noise.... all plastic parts are molded with zero moisture because the temps would make any water turn to steam in the press. Thus, after molding they need to absorb moisture back in the air. Normally a spur gear that you buy on the shop wall was made 6-12 months ago, but the Triad was only released in August. Most people that live in an environment with some moisture in the air will be fine BUT there are cases like guys from Colorado that have cold weather and dry air.
If you do have problems, you can soak your spur in a ziplock full of water for 24-48 hours to speed up the process and you'll be amazed at the difference. We had to do this for all of the original batch of gears which were made only weeks before the launch.
kdub is offline
Old 12-06-2012 | 09:11 PM
  #25254
Suspended
This is good to know.
TheGreatRL is offline
Old 12-06-2012 | 09:35 PM
  #25255
Wild Cherry's Avatar
Tech Legend
Thanks Kdub...
Its our wet season at TRCR , so no wonder my TRAID is so quiet ...
Wild Cherry is offline
Old 12-06-2012 | 09:37 PM
  #25256
Suspended
Originally Posted by Wild Cherry
Thanks Kdub...
Isn't it "wet season" 11 out of the 12 months in the year in Wa.?
Old 12-06-2012 | 09:51 PM
  #25257
Tech Legend
Everyone thinks it rains a lot in Seattle , facts are we have the best summer's...
Its never gets hot, usually 70 & blue sky sunny almost every day. Winters are no wetter than New York , Ohio or Virginia ...
Puget Sound s Area see's only a little snow each season ..
We like everyone to think its rains a lot here though ...
Kinda a local joke ...
Old 12-06-2012 | 10:38 PM
  #25258
Waflet's Avatar
Originally Posted by CaptainHowdyt13
Any major changes in setup to run the t4 chassis needed?
Hideeho
I couldn't get it to turn with a full size lipo. Shorty makes it great though. To go along with the shorty you need lots of foam battery blocks. I used combinations of small, medium, & large until I found where I wanted it. The I cut down an sc10 block to fit.
Oh yeah. The worlds body will fit, but not well. In addition to the FTW nightfox, you can use the proline j82 1/8 2wd body for a "normal" looking body.
Waflet is offline
Old 12-06-2012 | 11:19 PM
  #25259
FACTORYBUTNOT's Avatar
My buddy just got a Reventon Pro and he really likes it. He said it has much better feel than his Tekin RS that he used prior. Ditch the stock capacitor as its junk and get the Orion capacitor bank thingie!
FACTORYBUTNOT is offline
Old 12-07-2012 | 12:28 AM
  #25260
Just1More's Avatar
my TRAID is so...
It's spelled TRIAD.. I before A
Just1More is offline
