RC10B4.1 FT/WC
I am new to RC I picked up my son a b4.1 rtr he is 7 years old and has bleeding disorder . he keeps hitting the walls at are local track and braking the servo I went three 3 now stock ones what would be a good servo to get he's getting better so he might start racing soon.
Maybe I should listen to my own advice and maybe I won't hit the wall as much. Here comes Bob or John to say that is a good idea.
So those of you running shorty packs, is it worth it? Or if I stay with standard packs am I really missing out? I need to buy new battery packs since I only have one I feel comfortable with using. I can't afford to buy more than one right now and the idea of one standard and one shorty bugs me but if I switch now is the time.
I will be racing at ocrc and WC but most likely just practicing a few weeks before I get back into racing again, been over 2yrs thats what happens when you need to save for a wedding lol and now after it i gotta watch my spending at the track haha
better traction
feels more planted
not as plush (and harder to jump)
If I was running on a high bite traction I think it would be a lot better, but for tracks like mine it just depends on the conditions.
is that a good servo i been buying the stock one for 45 dollers that one 7 dollers
This servo.
http://www.hobbypartz.com/33p-solarservo-d770.html
Ran the 13.5 motor last night, no timing. Started w/ 28/75 gearing, that wasn't enough.
I ended the night w/ 32/75. Motor was coming off at 120 degrees or so. Still pretty darn slow and would only clear the triple for about 2-3 minutes in.
Not sure where to go from here. Might have a look at those d3.5 motors and see if the kv is higher w/ those....
I ran close to if not more laps w/ the 13.5 than I do w/ the 8.5. It just ain't as much fun.......
If it is a spec class with no timing you need to be geared so the motor is coming off the track at 150°. Anything less than that and you are leaving power on the table. If that is the case, play with motor timing to move the power band more timing moves the power towards top end.
If it is a spec class that allows esc timing you will need it to be competitive.
If it is open class and you are just running the 13.5 instead of your 8.5 because you already had the 13.5 then you need to either add timing (if that is an option on your esc), or gear up to get the most out of the motor. If you are just going to end up getting a new motor you might as well get a 10.5 instead of another 13.5. It is much better to run a little bit faster motor and gear it conservatively than to try and push the limits of a slower motor. Spec racing is one thing; if everyone is limited by the size of motor then you have to push it to be competitive.
The couple things you can do to your 13.5 will get a bit more out of it. If your 8.5 is too much for you even with a very conservative setup, and the 13.5 pushed to its limits is still not enough, a 10.5 should be perfect. Good on you by the way for manning up and motoring down. Way too many people put too much motor in their car and just crash a bunch. Get the slower motor figured out and focus on completing races without a single marshal. Then maybe back to the 8.5.
ah, the sanyo 1200 mah nicad days......... I dont miss those at all.
I am not sure I will ever be faster with a mod motor. I have always been and will always be faster with a stock unless it oval, lol. But, todays 13.5 is like some of the old school mod motors. It is definitely not like the 27 turn brushed. maybe like a 15 turn old school. For my skill, the 10.5 is the best motor for me. I can boost it a little if I need more guts, but in general, it is great.
Your gearing is still too low and you never mentioned motor timing.
I need some help with my lrp x-12 in my b4.1wc im geared at 35/72 with 4 dot timing, and i like the power, but it is very n controlable on some parts of the track, i do have a decent radio so i can tune down epas, but need all the throttle input on the tripple to clear it.
also how hot can this motor run? i heard it was 210 but idk, right now i am at 160-170
Right on , will do.
30/69 = 5.98
31/69 = 5.78
I mostly ran 32/75 which is 6.09, the motor timing was maxed at 50 degrees.
33/69=5.43 FDR. That's the lowest I've seen so far. I saw the kv for the d3.5 17.5 motor was pretty high, something like 3600kv. So I figured the 13.5 would be up there as well. Thanks for the info.
Just looked, the D3.5 13.5, the maxzilla version, has 4600kv. That's more than the 8.5t hobbywing, which is 4000kv.
http://www.trinityrc.net/shop/index....product_id=398
What is your reasoning behind running this 13.5? Is it for a spec class? If so can you run timing? Or are you running it in mod?
The 13.5 is the spec class I want to run at the upcoming trophy race. Normally I mess around in mod w/ the 8.5. 4x4SC is my main class and the buggy is just for fun and to see where I rank w/ the "fast" dudes at the track. I'm normally the quickest scrub.
Yeah, no timing in the esc. The motor, thunder power 13.5 z3r, had the max 50 degrees of timing in it. THe track has a long bermed up straight and a triple that comes w/ a short run up. So i need a little top end and torque, but I'd take making the triple everytime and give up the top end, if I could choose.
It looks like I need more gear. So I'll give that a try and see what happens. I have a pretty ho-hum style, I dont' take alot of chances and normally just try and keep it moving forward. I don't like working on the cars a whole bunch and I don't like spending money on replacement parts.
I'm lucky enough to get to watch some pretty fast dudes at my local track. The local track, Fastlane Raceway in Blue Springs Mo., is having a winter points series, I've ran the the first 4 of six races so far, which I think has me leading. I'll try and post a shot of the sheet.
Anyway, thanks for the help...
Here's a video of the tracks current layout.
http://youtu.be/TxLdCDcwqyA
31/69 = 5.78
d3.5 is pretty sweet! i went from a d3 at 69/33 max timing on endbell to a d3.5 same gearing with no timing and ... it was faster with more torque and cooler.
then i turned the timing up to 5* and it ripped even more with out sacrificing anything. temps come off at 125* after 6 mins.
that is where I will stay for now. very pleased with this motor.
try one
try one
i run 35/69 no problems with 30'C Ambient temp stock spec class, seems us aussies gear our cars allot more than over there!!!!!!
I presume you are talking about a 17.5? The last time I ran a 17.5 I was geared 36/69. Even higher than you Aussies. The sweet spot for a 17.5 is the same anywhere in the world. What you fail to realize is that we have been talking about a 13.5, not a 17.5, hence the suggested gearing. Now if you are running 35/69 with a 13.5, I have to ask how?
