RC10B4.1 FT/WC
Old 11-25-2012 | 08:59 PM
  #24601
Mxer59's Avatar
I rebuilt my BB shocks I kept getting them sucking back in towards shock bodies, no matter how many times I built them. I even tried the spring trick someone mentioned earlier. Still same issue no matter what, so finally, I just pulled down shaft unscrewed bottem shock body screwed it back on and it stopped doing it??? It no longer sucking in and when you pushed in it pushed back with normal rebound
Mxer59 is offline
Old 11-25-2012 | 09:13 PM
  #24602
Originally Posted by tschenck
Don't worry I just bought a b4.1, bb shocks the hexes and the updated slipper. That means Associated should release a kit any day now.
LOL
zipperfoot is offline
Old 11-25-2012 | 09:19 PM
  #24603
racer1812's Avatar
Super Moderator
Those having the shaft suck back in. After bleeding them do they still suck in after you "pump" them 10-15 times emulsifying the air/oil?
racer1812 is offline
Old 11-25-2012 | 09:22 PM
  #24604
Originally Posted by Wil Holmes
Hey guys ordering a new b4.1 what extra should I get while I'm at running in the mod class. I've heard about avid slipper but if I did that what slipper cover will fit over it anything else I should get? What's your thoughts on a Tekin 6.5 turn combo system or should I go lower or higher on motor turns?
Wil
I would suggest building your kit, driving the buggy, and then make adjustments depending on the track(s) you will race at and your driving style. Just because the avid hexes, big bores, or steering rack are popular upgrades, does not mean they are needed to be competitive.
A 6.5 in a 2wd buggy is a handful. If you have to ask, and unless you are experienced running 2wd mod, i would suggest no more than a 10.5.
Old 11-25-2012 | 09:32 PM
  #24605
I have found when i get negative rebound, i pump the shock shafts vigorously a couple of times and gets rid of the negative rebound. If that does not work, i extend the shaft, remove the bleed screw, and slowly compress the shock, rethread the bleed screw and you are done.
Old 11-25-2012 | 09:39 PM
  #24606
racer1812's Avatar
Super Moderator
Same for me, that's why I asked the above question..
Old 11-25-2012 | 09:52 PM
  #24607
I have ran some wild cars in my past but it has been awhile I'm leaning now toward the 8.5t from tekin which would probably be perfect for my indoor clay track. Thanks for the help
Wil Holmes is offline
Old 11-25-2012 | 11:19 PM
  #24608
Gonna have to try this. I redid my shocks several times using different techniques to get rid of the sucking in and couldn't. If all of them rebound and suck in the same will this still be an issue with the handling of the car?
Ctimrun is offline
Old 11-26-2012 | 05:11 AM
  #24609
beidle99's Avatar
I made the little carbon shelf that fit under the U-brace last night to mount the esc on. Looks pretty factory if I say so myself. I'll snap some pictures once I get home from work today. The only issue I see with mounting the ESC in the middle is that I am pretty locked in with the location of the shorty other then moving it forward, but it would be the same if the esc was mounted down inside the tray.
beidle99 is offline
Old 11-26-2012 | 05:39 AM
  #24610
Venom1836's Avatar
When converting to hexes how are the quality of the JC hexes?
I really want only JC parts on my buggy.
Also what allows the wheels to spin with hexes?
Do the bearing that I used to use in the wheels go in the steering blocks with hexes?
Also I am guessing I need axle pins up front too?
What is the part # for the lock nuts that go in the hex steering blocks?
Thanks and sorry for so many questions.
Last edited by Venom1836; 11-26-2012 at 06:19 AM. Reason: Never mind about the BB Shocks
Venom1836 is offline
Old 11-26-2012 | 06:22 AM
  #24611
Allen720's Avatar
if i purchased a set of team associated big bore springs would i be safe with getting the soft set or are you guys getting into the medium set as well. I will have them on a b4.1 and a b44.1
Allen720 is offline
Old 11-26-2012 | 06:33 AM
  #24612
t0p_sh0tta's Avatar
Depends on you, your track, and the tires.
t0p_sh0tta is offline
Old 11-26-2012 | 06:43 AM
  #24613
Allen720's Avatar
all the tracks are hard packed indoor medium bite. i usaully go with a barcode or something like that. i purchased some v2 shocks with losi big bore springs but only have a single set so looking for something that i can change and adjust with.
Allen720 is offline
Old 11-26-2012 | 06:53 AM
  #24614
LOL you are worse than me..... Put the ESC where it's supposed to go.
Bob Barry is offline
Old 11-26-2012 | 07:45 AM
  #24615
Suspended
You may have run some "pretty wild" cars before, but have you ever run them on a track? Driving on a track is much more difficult than you think. Here is the thing. If you have no clue what you are doing, it is best to copy those who do. The top drivers in the WORLD don't run 6.5 turn motors in 2wd buggies for a reason. It is just too much power for a 2wd buggy on a track. If you want to do it right from the start, get a 17.5 and run it with no timing. In about a year when you can make it more than a couple laps without crashing, turn the timing up. If you get a mod motor you will just get frustrated, trust me, I have been in this hobby for 20+ years, and have seen this happen more times than I care to keep count. Especially with the guys that started with SC trucks.
Was it not possible to mount the shelf you made high enough to allow the battery to fit underneath it?
There were some issues with the JC hexes stripping out where the little screw for the clamp went. I think the fix was a slightly longer screw. I don't know if the longer screws are included, or if you have to buy your own. You will need front wheels with a hex pattern instead of the bearings. The locknuts for the hex front axles are the same as the rear axle. Really?
R.Shackleford is offline
