RC10B4.1 FT/WC
#2131
#2132
Just so I'm clear, You guys are grinding the new U brace flush and adding a .030 washer.
I know the orginal U brace from the original B4 was flush and then they added the extra height.
I haven't measured it but the raised section of the new U brace can't be much more than .030 high.
I tried this setup last night at the track and I think I like it. I tried the new C tower with a .030 shim under the inner ball stud for a pack and then tried it without the .030 shim. I found that without the shim under the ball stud, the car would tend to over rotate a little more. I was running on a track that is very, very smooth, and has pretty good grip.
#2133
#2134
Not too informative, but my almost FT T4.1 for consideration
V2 shocks will be in by next race day.
#2136
#2138
AE Is Killer Of All......
Best Fleet there Is .... Just Look at there Resume ...........
Rest are
Rest are
#2140
Finally the outdoor season is upon us, here in the east. What tires and inserts should I have in my arsenal for 2wd Mod Buggy? I would like several options. Most of the tracks are medium bite clay with some dusting but one track has poor traction because it's loose dirt that dries out easily.
#2142
#2143
What about Proline Suburbs M3 compound? also, what inserts should I be using when using a soft compound?
#2144
In a 2wd buggy you'll want to run firm inserts with soft compounds. Pro-Line's countour foams work really well. Epic Bomb Ones also work well.
#2145
Super Moderator
Trader Rating: 31 (100%+)
I would have to agree with mdowney that a suburb style tire will only work out door if it's a high bite hard pack clay, they just don't like a lot of dust. I like Hole shot 2.0's and other tires in that style on dry dusty tracks, every track is different but I leave the bar codes and suburbs for inside..
