RC10B4.1 FT/WC
Old 06-25-2012 | 07:57 AM
  #16021
Originally Posted by t0p_sh0tta
No, it's not true. The Traxxas lowers come with an upper collar that slides over your stock upper collar. The Traxxas collar is wide enough to keep the springs in place, while your stock one is not.
thank you sir
dougwalter911 is offline
Old 06-25-2012 | 08:24 AM
  #16022
CraigMBA's Avatar
Originally Posted by elex300
I read that some of you say the Traxxas bottoms work as well. When I did my conversion a few weeks ago I tried the Traxxas bottom but it would'nt slide down over the eyelet like the 22 did. Am I missing something here? I have no issues with the 22 bottoms but im curious.
They are quite snug, but they do fit. Dimensionaly exactly the same as the 22 bottoms.
CraigMBA is offline
Old 06-25-2012 | 08:34 AM
  #16023
brent701's Avatar
Originally Posted by dougwalter911
I was told with the Losi springs I only need lower collars like traxxas or Losi not uppers I can still use stock uppers, is this true?
also. The traxxas lowers do not fit correctly without modding them.
I use the Losi TLR5095 lower cups
brent701 is offline
Old 06-25-2012 | 08:48 AM
  #16024
Waflet's Avatar
Originally Posted by Waflet
Hideeho
What, if any, are the differences between asc1766 LIGHT WEIGHT out drives & asc9852 out drives? Pics on amain show the opposite ends of each so I can't tell.
Hideeho
Upon further reading I found 1766 is listed for the b/t4 & b/t4.1 but the 9852 is listed for only b/t4.1. I'm guessing the 9852 uses the metric bearing & the 1766 uses the standard. Is this correct?
Waflet is offline
Old 06-25-2012 | 09:09 AM
  #16025
Thanks for the advice. The chassis is a foregone conclusion, I like your other suggestions. I was surprised at the motor and ESC myself and will be keeping those. I did make an order for an upgrade on the servo.
WindsorRacing is offline
Old 06-25-2012 | 09:42 AM
  #16026
CHIZZLE's Avatar
I call bs. Mine went right on.
CHIZZLE is offline
Old 06-25-2012 | 09:53 AM
  #16027
brent701's Avatar
lol....
brent701 is offline
Old 06-25-2012 | 11:55 AM
  #16028
Wildcat1971's Avatar
I feel the same way. Since I put the BB's on I find my self at wot in places I never did before. Same with my SC10.
lol, 4 weeks ago you posted "if it aint broke done fix it". Now your converted to big bores spring, lol. I found your post when looking up the part numbers.
Wildcat1971 is offline
Old 06-25-2012 | 11:56 AM
  #16029
I am thinking of doing the BB spring conversion. I would prefer losi springs, because i can get them easier at the lhs. Are the Avids that much better than the losi?
Old 06-25-2012 | 12:06 PM
  #16030
t0p_sh0tta's Avatar
No. Save a ton of money and start with the Losi.
t0p_sh0tta is offline
Old 06-25-2012 | 12:12 PM
  #16031
I checked there spring rates. I currently use brown front and silver rear. So I would think Losi Yellow rear and losi orange up front would be equivalent. That sound about right?
Old 06-25-2012 | 12:46 PM
  #16032
tedstryker's Avatar
I believe your right I'm running losi yellow on rear Orange up front...they work great for my track ...I'm using them with kyosho velvets....
tedstryker is offline
Old 06-25-2012 | 12:54 PM
  #16033
bds81175's Avatar
Moderator
Interesting. I'm looking at expanding my spring collection for my velvets. The K springs are stupid expensive. Do the Losi's fit on there without all the hoopla with aftermarket collars and such?
bds81175 is offline
Old 06-25-2012 | 01:13 PM
  #16034
tedstryker's Avatar
Fit like a glove with K. Collars
Old 06-25-2012 | 01:15 PM
  #16035
Yes, they work perfect on velvets. Use traxxas upper retainers and the losi lower cups TLR5095 pick up Losi red and orange front springs and white and yellow rear springs. Keep the Associated lower eyes. This mod can be done for around 30 bucks. This setup gives you plenty of ride height adj. You need to come back to Muskegon / Hesperia to race!!
nhraman is offline
