Really Expensive Servos
#47
A high dollar servo wont make you faster. If your not used to a faster
servo dont buy it. I run servo's that have .15-.17 speed. they
work just fine for my needs. If I went to a faster servo Id have to learn
how to drive all over again because it will not drive the same.
I say if you like the $35 servo stick with it. I cant seem to spend
over $100 on a servo. But I know people that run $200 servo's in thier cars.
One thing is as long as the servo is digital your covered on steering in 1/10th.
Brushless servo's are used in high torque applications like truggies
and 1/8th.
Another thing I dont understand is why have a titanium geared servo??
I think it's pointless myself...
That's either for a really bad driver, or someone that has had bad luck
outa a regular metal geared servo. I have never stripped gears in
a metal geared servo and my servo's are a few years old....
and 1/8th.
I'm with you.
They use "titanium", because it makes for good marketing.
Sure, racers use $200 servo's, because they don't have to pay that much for them cause companies want racers to use their products to advertise them.
I'm sure a $200 servo doesn't suck, but the real question is; is it 4 times better than a $50 servo?
#48
Preach!
I'm with you.
I'm with you.
(knock on wood)
#49
#50
Preach!
I'm with you.
I'm with you.
I dont buy my RC equipment just because it has a 'turbo' sticker or it comes with the most colorful box. Thats like saying sticking a 'GTR' sticker on your full sized car will give you an extra 50HP.
Dont get me wrong, I do have $30 analog servos that perform very well within low stress, normal driving+bashing sessions at the beach or in the rivers and they are easy to waterproof. I wont get a sleepless night if one gets damaged.
#52
So, basically, for you, it's worth spending 4x the amount just for "peace of mind", because you say that the actual $200 servo itself is not 4x better.
Then, it's a psychological thing for you, it seems.
For me, I am at peace and rest easier knowing I have good products AND extra money in me pocket.
#53
Titanium is a lighter metal and can be 'replaced' if ever.When your skills develop through practice, you can sense the advantage of using faster servos. I'd have to disagree with using 'titanium' as a marketing gimick. Titanium aftermarket parts either in full scale or minature scale almost always is an advantage in most applications.
I'm not buying the weight argument in a servo. In the first place the gears in a servo are very small, so much so that weight is hardly a consideration.
I don't disagree on the speed of the servo advantage, even though you imply my skills may not be up to yours . However, you don't know that, so you're just guessing.
The use of titanium outside the world of RC, or in RC areas other than in a servo, hasn't been part of this discussion. I'm well aware of the use of titanium in products where it has been beneficial. But, this discussion is about servo's.
Marketing/advertising goes on in every product sold. It has to be that way, nothing really wrong with it. If the use of titanium gears is truly an innovation and game changer, then I would seek those servo's out.
You feel that the use of titanium in servo's is not just marketing.
That's cool. You're certainly entitled to your view, and you might be right.
I'm just stating what I think about it. To me, the use of titanium addresses a question that no one asked.
What is there about standard metal gear servo's, that titanium addresses?
Is there really a need for titanium gears in servo's?
#54
Hmmm....
Buying a faster servo has helped my lap times tremendously, and I do not break as many parts as I used to because I drive better. I did not spend $200 and I do not recommend $200 servos. I recommend a $99 Hitec 7955.
#55
Been a Futaba user all my life, I just find that there are lotsa choices of servos out there to suit the applications. IMHO, the weight advantage of titanium gears in these servos will be very minimal, so if it gives me a 'psychological' advantage that I'm using the best, lightest parts...then so be it.
At my LHS we have Sanwa/Airtronics, Hitec, Futaba, KO servos that suit all kinds of budgets and all kinds of applications. I've swapped out the 'standard' racing servos in my 1/8 cars for the new batch of Savox servos and I am glad to say that it was a good investment. I went back to check on the Savox website to see what they say about using titanium as a material in their servos gears. I can see where they are standing, and I wont risk my races being ruined because of servo failure.
The issue of standard alloy/steel gears VS titanium gears is very intriguing for me. Hope there are brilliant minds to bring up some points in the pros/cons of them used in servos
#56
The servos comes with all mounting hardware including rubber grommets and the usual stuff. I was pleasantly suprised to see a decal sheet and the servo's box can double as a small parts container that snaps shut
#57
If it works for you thats great, its cool there are a lot of affordable components that work quite well these days.
But in my experience steering while sitting is not the issue, but rather while hard in the corner under a lot of side load is one area where I have noticed the difference. That and just raw speed, the ability to react to slides and such.
May I ask which servo it is?
#58
Yes I will agree with you, it is a mental thing. I buy extra a arms and hub carriers for all of my cars, again for "piece of mind" since my shops do not carry them for my 1/8 vehicles.
#60
Actually I would be one of the guys with access to the tools to do the testing, just never found/made the time.
On a more practical level, if one is involved in racing and makes a few friends it’s not that hard to get a chance to see and try similar or the same cars with different servos. Yes setup differences and such can blur the comparisons some, but one can still develop a feel for their individual needs/tolerances I think.
I agree the specs do vary some from brand to brand, but I haven’t seen wildly misleading differences.
Everyone needs to make their own decisions, but for us there is no question that fast servos improve our performance. My Son because he can take advantage of it, me because I need all the help I can get!
I see the servo as very important, I think there is a very good reason why they plug into channel #1.
For what it’s worth, my fav 1/10 scale servo is the Futaba BLS451. Good speed, maybe even a little better than the rating, plenty of torque, and very smooth, not jittery.
