E-Revo Brushless
#31
I will go with that charger then! I will need (2) though correct?
What kind of plugs would you recommend I purchase?
I would also like some recommendations on Lipos too.
btw: I got my ERBE for 550.00 brand new! came with black body!. I was gonna pick up the slash but when I found this it was too good to pass up!
#32
Yeah, if you want to charge both at the same time, it'll take two chargers. You could buy one powerful charger and charge them in parallel, but it'd need a DC charger and a power supply - the two AC6s will be cheaper and prob just as quick.
I thought the ERBE comes with Traxxas plugs. If it does and you cut them off, you'll void your warranty. Towers ad says hi current connectors and that usually means Traxxas connectors. Traxxas' site is down atm, so I can't go look and see what is there.
Regardless if its 2S or 3S, I think I'd look at the HK nano-tech lipos. Something at least 5000mah and 30-35C. They have to fit your battery boxes.
Sounds like you found a good price....
#34
Hello everyone anyone interested in buying an erevo pm my... There are two for sale.
#36
#39
They are the flightmax 5000 they go by mah so go near the end.
#40
My buddies run them and they swear up and down they are as good as the reedy 5000s
#41
These are all capacities, but all 2S -
http://www.hobbycity.com/hobbycity/s...=&LiPoConfig=2
These are all capacities, but all 3S -
http://www.hobbycity.com/hobbycity/s...1&LiPoConfig=3
I don't know what the size is limited to by your batt boxes. The above lists alos has LiFes and NiMhs in there (only way they list them in mass). My experience with the size info that HK shows for their lipos is that they usually wind up actually being bigger, not smaller, so give yourself a little leeway.
