Tamiya TRF2WD thread
#1651
hey guys, i got a work injury last night and going to be out of work for a little time so my buggy and truck got to go. so i figured i would give you guys first dibbs on them, the buggy comes with a bunch of spair parts aluminum hubs 0 and .5* hubs also aluminum rear hinge pin brace. good body. also selling the 201t includes a roller with multiple sets of rear quick change tires no body. pm me for more details and picks will consider all resonable offers! thanks in advance!
-cantrell-
-cantrell-
I'm sorry to hear this. Wish I had the extra cash to pick them up off of you. Good luck and heal up quick buddy.
#1652
In that case when you get it scrap the stock diff balls. Pick up some ceramic. Buy Ae brown front springs and green rear and the spring cups. Use Randy's base setup off the TRF website. It will get you in the ball park and then tune to your liking! Let us know what's going on and we can help ya get her figured out!
#1655
R/C Tech Elite Member
Yes it was a really good night for the Tamiya drivers. Two of those Tamiya cars in the top 5 were virgins, including mine! It was the first time i really got to work on the car, I am really impressed on the overall performance of the buggy. BTW, thanks for the hook-up Randy. Can't wait to get out there again...
#1656
and another tamiya newbie enters the fold, thanks for all the advice on bits too get, i have a load on order, but in the meantime i would just like too say that the buggy is awesome. i couldn't be happier, so much better than my old cougar.
After 3 rounds of fettling, i managed too qualify 3rd in the B which i completely dominated, and won by a good margin. my time was good enough too place 3rd in the a main, so i was very happy indeed.
the car is completely stock in every respect, white springs all round, stock damper internals, stock shock settings, just 45g over the servo and 10g on the very front. it does seem too have a very slow body transition in high speed corners and a little twitchy at the front, too much weight do you think? or is it because i run on carpet indoors, with mini pins. anyway any advice you can give i would greatly appreciate. i am looking through the plethora of setups out there and i cant seem too decide what way too go, so if i can pick your brains (collectively i hope) so i can get a rough idea of what way too go then i would appreciate it.
Many thanks guys.
Taplowrc.co.uk is the website address so you can see the kind of surface i run on and the general type of track layout we get
Many thanks guys.
#1659
Edit: Nevermind, I found some. 3/32", right?
Also, is there a difference between brands? ProTek is $9, HPI $20, Xray $30, and Kyosho is $35!
#1660
#1661
Front... 32.5w Losi w/ 1.4 pistons - Green Tamiya 201 option springs (one step heavier than the stock black springs) No limiters. Shock mounted 2nd hole from outside on tower, outside on arm.
Camber link, inside on bulkhead, 2 mm washer (take out washers if you want to make the turn in a little more agressive) Inside on hub. Hub spaced "middle".
Rear... 25w Losi w/1.3 pistons - Yellow Tamiya springs No limiters, shock mounted 3rd hole from outside on tower, middle hole on arm.
Camber link, inside on bulkhead w/no washers and outside on hub (middle is stock) Hub spaced forward.
1 deg camber all around, about 1 deg toe out.
Ride height is 22mm in front and 24mm in back.
Stock body, large Tamiya wing with 2 lines cut off the "wicker".
7g in very front bulkhead, 14g in front of servo, 7g on each side of battery at the front of the battery box, and 21g behind the battery, 56g total in the car. Definitley feel that the car could use more weight though to feel a little more planted.
Tires were Proline MC Suburbs with AKA red foam cut to fit and Proline MC Scrubs in front with 3/4 rear foams and no tire sauce.
All in all, my car responded very well to changes as the night progressed. It had great initial turn in and very good on power steering and the car was very stable. Qualified 10th and I had to bump into the A main from the B. Ended up 4th overall after a 3 way Tamiya 201 battle on the last 2 laps!
#1663
First of all THANK YOU Aaron for your support of Track Star!
Thanks to all of the Tamiya drivers team and privateers for making it to OCRC last night. It was great to see all of you out there having a great time.
Pres; Great driving! Solid and consistant. For only your second time on the track with your 201 it looked great.
Steve; Sorry the ESC was giving you hell. I can't wait to see how fast you are with one that co-operates!
Randy; Thanks for being there to help everyone with tweaks and tunes. You're car looked very solid.
Josh; Great meeting you and you looked good out there with your new ride. Keep it up!
As for me...... my only excuse was that it was past my bed time..... Oh yeah, I've been sick too...
