Durango DEX210 Thread
#9346
http://www.amainhobbies.com/product_...aft-Set-Gold-2
After they were mounted i noticed the driveshafts were further in on the outdrives at full extension. But even before the upgrade i did not have any outdrive issues.
#9348
Take a look at the pics of my 210 in my profile album. If have a top down shot where you can see the inner holes on the Tresrey mount are directly above the mounting holes on the tranny.
#9349
camber fix
I ripped a ball stud out of the transmission case tonight. this was my fix Does anyone run this http://www.tresrey-usa.com/tresrey-a...est210desc210/ If so how do you like it and is it worth it. It got me threw the night and I even took 2nd in the main but it pushed like a school bus.
worth checking out
#9351
On a side note, i upgraded my rear shock shafts to the ti-nitrate ones. This is an option part and i found them to be 3mm shorter than stock.
Kinda bummed, looks like fixing the diff won't be cheap, no matter what option I go.
#9352
I am giving the DEX210 and 410 a try, they will be here tomorrow. I had a couple questions:
Which shock shafts do I want to run? Do I want to run the ti ni black or ti ni gold?
Are most running the 1.3/1.4 tapered pistons, or shall I just drill the blanks that come in the shock piston kit?
Dave
Dave
#9353
R/C Tech Elite Member
Dave
Dave
#9354
Anyone know if the Finnisher body fits the +8 chassis?
#9355
is their any disadvantage to ball studs not being titanium i can get tlr22 super duty titanium turnbuckles with cups then tlr22 studs for $46.38 vs the $79.99 for the dex210 kit, studs are different lengths but no reason not to work that i can see im starting to get play and popped cups so ill probably change them soon and i could always replace the studs if they ever snap for alot cheaper than other broken parts might cost
#9356
It fits, but its not perfect..The side pods on the +8 chassis has bumps that are not designed into the Finnisher..
Ti studs are stronger, but more $$. If you are concerned about breaking the steel ones, or have already, then thats your fix. I have been running the stock ballstuds and cups, and had no issues, no popoff's and very little play, maybe it has to do with pre-assembly. It has been mentioned plenty of times, but most use a 3mm tap before assembling them, and you can almost adjust them by hand..
#9357
#9358
Yes, the Finnisher does fit the +8mm body. The only thing is the side pods are a little different than the side pods that are used Alum. chassis. So there mite be some tight spot with the body hitting the chassis. I have all three bodies for the DEX210(Proline, Jconcepts and Stock Cab forward +8 body).
Dave
Dave
#9360
