Durango DEX210 Thread >
Like Tree80Likes
Old 12-07-2012, 04:00 AM
  #9061
Trader Rating: 125 (100%+)
Originally Posted by Pinionizer
Hey guys need some opinions. The exotek parts for is buggy are they just all bling or are there performance advantages with the parts. Looking at getting some parts but not sure which to get. Any input would be much appreciated!
The steering link, brass weight, and locking hubs would benefit you the most. Some will say the carbon towers to bulletproof the buggy, but I've never had big issues with the kit towers.
kwiksi is offline
Old 12-07-2012, 04:58 AM
  #9062
The Czechexican's Avatar
The THREADED SHOCK POSTS are a nice option too when tuning with the shocks. A lot easyer then those stupid locking nuts. +1 on the brass weight.
The Czechexican is offline
Old 12-07-2012, 08:09 AM
  #9063
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Hey everyone. What are you thoughts on the RTR Dex210 versus the pro?
Reason I ask, tower has a pretty killer deal right now on it. basically $300 out the door with a lipo if you are a member.
Do you still need to buy the same upgrade parts like the steering link for the vehicle?
Cain is offline
Old 12-07-2012, 09:21 AM
  #9064
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
I bought the DEX210 RTR version about a month ago and I couldn't be happier. Some things you need to know:
It comes with a DIMEC +8 Chassis - handles a lot better than the aluminum chassis (see the previous posts on the last couple pages that attest to the DIMEC chassis).
It comes with a gear diff instead of a ball diff - bonus there!
It comes with a nice bag of extra/spare parts for tuning options.
I haven't had any issues with the steering other than a little slop... but I'm going to swap this out anyway because I don't want it to fail when I need it the most.
The pins in the rear wheel nuts are incredibly easy to lose... they fall out way too easily.
It has been put together very well. I have raced two weekends thus far (6 quals, 2 mains) and have not popped a ball cup yet (knock on wood).
The stock tires are way too hard to race on anything.
The stock gearing is 81T Spur/29T Pinion/2.6 Internal Ratio - If you try to put anything higher than a 30T pinion, you'll have to modify the motor mount to get more space. You could get a 75T spur and then your gearing options are better or you might want to look at getting a Speed Passions 10.5 motor to go with it. They were having an awesome deal on older motors since they are releasing new ones very very shortly (got mine for $50).
When I replaced the receiver with a futaba receiver, it made the steering servo glitchy and it would move on its own... so I would put in something else... can't go wrong with a low profile Futaba or Savox.
Best part about it... if you can get it for $300.. that's $100 less than I paid and I'm not the slightest bit upset about what I paid for it. You are going to like it, no doubt about it. It's fun to throw it on the track with the RTR paint job and smoke fools. But, if you are going to get a clear body, make sure you get the +8 one.
Either way, you can't go wrong. Nothing's perfect... exept the DEX210.
ewashburnaf is offline
Old 12-07-2012, 09:26 AM
  #9065
Tech Legend
Cain's Avatar
thanks for the info. I had a DEX210 in, was pretty clean one run roller with some spares, etc. Sold it as I was thinking of running something else for 2wd but liked the feel of it as far as what I saw.
I run speed passion gear exclusively so the current setup would be a bonus and have an 8.5T V3.0 sitting here NIB. Its full on mod here so that could be used with the GT2.0 Pro I have available.
The stock tires, wonder if they would work for carpet?
Are the ball cups on this versus still an issue like the pro vehicle?
Cain is offline
Old 12-07-2012, 11:43 AM
  #9066
Originally Posted by Doughty
450cst in all the shocks
3000cst in the diff
thank you
twisted is offline
Old 12-07-2012, 02:20 PM
  #9067
Trader Rating: 26 (100%+)
Default DEX210 Aluminum Servo Horn
Does anybody use one? If so which is the best?
Ssilverfz1 is offline
Old 12-07-2012, 02:49 PM
  #9068
P6
i bought a three hole alum racers edge just real quick at the track because i stripped the plastic one i had to add 2mm of washers under the servo just so the end of the horn will clear the bellcrank but i do feel like it has more steering control using a longer arm
P6 is offline
Old 12-07-2012, 06:15 PM
  #9069
nolimit208's Avatar
Originally Posted by twisted
thank you
If you rebuild the diff I would recommend trying it with regular black grease, small amount just enough to coat the gears. Car rotates and doesn't push as bad, I ran 1 and 2k in diff but found the black grease is much better and their many that do the same
nolimit208 is offline
Old 12-07-2012, 07:07 PM
  #9070
Trader Rating: 57 (100%+)
I'm going to get mines tomorrow. Hobbico made it $230 this weekend.
http://www.bestrc.com/promos/december-deals/index.html
shagino is offline
Old 12-07-2012, 07:19 PM
  #9071
Trader Rating: 29 (100%+)
With the coupon and sale you can get it at Tower for $209.00 I just might grab another at that price.
Walkman is offline
Old 12-07-2012, 08:49 PM
  #9072
i ran mine for the 1st time tonight in bone stock form except i use suburbs on the rear. it pushed.
twisted is offline
Old 12-08-2012, 12:48 PM
  #9073
nolimit208's Avatar
Ya put black grease in the diff, it will limit the amount of force that is applied to the outer wheel when on power in corners which eliminates the push drastically.
Old 12-08-2012, 01:43 PM
  #9074
Azagar's Avatar
I current use 700cst in both my SC and buggy gear diffs and couldn't be happier if you want to try the oil route.
Azagar is offline
Old 12-08-2012, 01:48 PM
  #9075
Trader Rating: 56 (98%+)
Seriously... with the sale and the december super saver coupon, 189.98 shipped for the dex210 kit. Cant beat that. Just ordered.
jhhack is offline
