Durango DEX210 Thread
#8794
hey guys i just ordered one of these kits to replace the worn out xxx-cr that i have been racing and winning with for well over 8 years! i wanted to know what tooth spur comes with the kit and what pinions to buy that willl give me the best ratios for multiple tracks i race: open loose dirt, open hard packed indoor, and tight hard packed. thanks guys
#8795
#8796
R/C Tech Elite Member
I myself use toothpicks, dip them in CA, push them in snug, cut flush and a drop on the top to seal them up. It takes a little time, but works good. Some use the solder gun, and melt them shut, but I tried that, and it's not as pretty, and makes it even harder (I'm getting old) to see those little darn numbers.
#8797
Has anyone used the TSR ceramic diff kits? If so what did you think of them? Thanks
#8800
Try this setup if you run on dirt/clay w/ medium traction, and go from there.
http://www.team-durango.com/pdf/setu...29_01_2012.pdf
#8801
My DEX210 just arrived today, looking forward to a couple of nights wrenching ahead.
Planning on running a 10.5 LRP in it, as our track is about 30 seconds a lap, low grip, very dusty/small rocks, find the boys with 7.5 cant get the power down before having to wipe it off again before the corner..
I believe a RM3 setup would be the ticket
previously a B4.1 owner...
#8803
#8804
I found that the box setup is ok at best. I have been using Jorn's setup from the reedy race with some minor tweeks and it is the best my dex has ever felt. It drives absolutely amazing.
