Durango DEX210 Thread >
Like Tree80Likes
Old 04-30-2012, 11:27 AM
  #5671
Trader Rating: 166 (100%+)
Originally Posted by flame56mx
i am running the ftw, but its mounted cpt america style, no problems..
with that setup what are you using for ballstud washers?
jpcopeland1 is offline
Old 04-30-2012, 11:29 AM
  #5672
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Raul Garcia
I use the Racers edge one, bought it prior to my Tresrey days.
x2 on that Got it froma used roller. no thickness issue there.
aloksatoor is offline
Old 04-30-2012, 01:10 PM
  #5673
LoudOne's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Jonny5
There's a diff build guide on the TD website (In The Pits/Tips and Tricks) that is very detailed and specific. Follow that guide and you'll be golden
I did.. I even posted the video on the previous page of this forum... But if you've all built a DEX210, what side did you put the open bearing part of the thrust bearing on? It just threw me off when the RC Car Action article stated the opposite of what you see the guy do in the video... No where in the video though do they mention what side the thrust bearing goes on.. You just see him put it facing the small spacer...
LoudOne is offline
Old 04-30-2012, 02:05 PM
  #5674
Trader Rating: 19 (100%+)
It really shouldn't make a difference which way the caged thrust is in there as long as the washers are in the correct order. Technically you could use regular thrust balls and have the same function. No issue there whatever way you placed it.
Jonny5 is offline
Old 04-30-2012, 02:35 PM
  #5675
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Originally Posted by symmetricon
The rcshox isnt temporary It works just as well as the treysrey. I have been running the v2 for several months with no problem whatsoever.
Going by RC Shox's description on the website, it seemed like it was a temporary fix until spare gearboxes were more readily available. I didn't know it was an alternative mount like the Tresrey.
+1 for the Tresrey mount. 4mm carbon fiber- will not break, period. Plus cf is just sexy!
Thanks. I might have to pick one up.
BOLISARIO is offline
Old 04-30-2012, 02:45 PM
  #5676
aloksatoor's Avatar
I have the rcshox but frankly the stock mounts not yet broken with 3-4 solid days of crashes and tumbles.
Old 04-30-2012, 03:24 PM
  #5677
symmetricon's Avatar
Trader Rating: 27 (100%+)
I broke my inner camber mount as soon as I switched ballcups and rod ends. Thanks god that marcus made those parts or I would have been SOL for quite a while.
symmetricon is offline
Old 04-30-2012, 03:33 PM
  #5678
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Stock ballstuds and ballcups work great, no need to switch. I had the Tresrey mount on the back but took it off recently.
Jmuck69 is offline
Old 04-30-2012, 03:45 PM
  #5679
aloksatoor's Avatar
I use the HPI 4.8mm ball studs and the 4.8mm lunsford ball ends with the 3.5 super duty buckles. Been golden ever since popped one with a front smack in the house while testing but it was at full tilt.. Never again on track though....
Old 04-30-2012, 03:46 PM
  #5680
nolimit208's Avatar
Just put the gear diff together and its seems to bind a little bit like it compresses to much. Should I just allow it time to break in?
This is the guide i used
http://www.petitrc.com/setup/durango...bly/index.html
nolimit208 is offline
Old 04-30-2012, 03:47 PM
  #5681
Thats good that they worked well for you, but not for me. I recently switched to the lunsford kit and had one ballcup that would pop on and off with easy. It actually popped off just from a hard landing, not even a crash. Since then i started using the 22 cups instead of the lunsford cups and no more problems.
Old 04-30-2012, 05:59 PM
  #5682
Jmuck69's Avatar
This car is a tank! This past weekend I was coming onto the straight and popped a wheelie due to the awesome power of Orion. When the wheelie happened I lost traction and spun out while a E buggy ran into me at full speed. The only thing that happened was a popped front camber ballcup. I popped it back on and ran immediately. Kept the same ballcup on the entire night with no issues.
Jmuck69 is offline
Old 04-30-2012, 06:28 PM
  #5683
TAMAK's Avatar
Trader Rating: 29 (100%+)
+1 on the 22 cups. I only run them on the rear camber link though.
TAMAK is offline
Old 04-30-2012, 06:45 PM
  #5684
R/C Tech Elite Member
Trader Rating: 520 (100%+)
1mm on the rack, 0mm on the spindle, using Losi ballstuds (they are a little taller)
flame56mx is offline
Old 04-30-2012, 09:49 PM
  #5685
Gotcha.
