Durango DEX210 Thread >
Like Tree80Likes
Old 02-12-2012, 11:49 AM
  #4321
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Raul Garcia
On my 210 and 410 I am using the J Concepts 12mm hex for the b4.1, spaced with the 2mm spacer. I use Associated roll pins for the hexes. Not one problem here, and putting down plenty of power..
I did have the opportunity to run a gear diff the other night. I filled it with Losi 5k, it defintetly accelerates faster, but steps out easier. I need to get that nailed down.
Could you post a pic of the JC hub installed? I have been looking to make the conversion.
Jmuck69 is offline
Old 02-12-2012, 12:23 PM
  #4322
Trader Rating: 79 (99%+)
Raul Garcia is offline
Old 02-12-2012, 12:45 PM
  #4323
Jmuck69's Avatar
Thanks! So for the 210 you attach the B4.1 hex hub w/o the spacer? Using B4 hex rims the offset is matching with stock? Also, how are you liking the Lunsford turnbuckle kit?
Jmuck69 is offline
Old 02-12-2012, 12:49 PM
  #4324
actually I use J Concepts mono wheels for the 22. I also use the 2mm wheel spacer behind the associated roll pin, even though its not pic'd.
Old 02-12-2012, 01:16 PM
  #4325
Try the AE roll pins. They don't fall out and you'll have them then for when you convert to the JC 12mm hexes
Jeff Harris is offline
Old 02-12-2012, 01:31 PM
  #4326
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I think I started to try one... and they were too tight. not sure i would ever be able to get them out. Or am i thinking of a different pin?
Cpt.America is offline
Old 02-12-2012, 01:36 PM
  #4327
Autocratic's Avatar
Trader Rating: 26 (100%+)
The AE compression pins should work too.
Autocratic is offline
Old 02-12-2012, 01:58 PM
  #4328
Redwings's Avatar
Originally Posted by Cpt.America
Had another DNS in a big race this weekend due to TD quality control issues... Wheel hex pin broken in two. Anybody know of any direct replacements for the hex pins?
When I'm in a tight situation, I trim down an old body clip to fit
I have also used a metal coat hanger to fix the problem, but you have to find the skinny ones that will fit into the hole on the axle.
Redwings is offline
Old 02-12-2012, 02:09 PM
  #4329
Redwings's Avatar
Default Battery Question
Hey guys,
New owner of a 210 but trying to if I can use a regular battery pack or do I have to use a shorty pack? I have heard some say shorty or saddle packs.
Also any gearing suggestions for starters.
Paul
Redwings is offline
Old 02-12-2012, 02:14 PM
  #4330
Autocratic's Avatar
You can use any three types of batteries.
Old 02-12-2012, 02:52 PM
  #4331
Autocratic's Avatar
Nice long chassis shot. This car also has a brass front weight under the servo; has TD logo.
Old 02-12-2012, 06:10 PM
  #4332
Redwings's Avatar
Sweet, So I just remove the from battery brace (stopper) near the servo. Cool Thanks
Redwings is offline
Old 02-12-2012, 07:44 PM
  #4333
Jmuck69's Avatar
http://eos.redrc.net/wp-content/gall...ansmission.jpg
New vented slipper plates?? Also shows the milled motor plate.
Jmuck69 is offline
Old 02-12-2012, 07:48 PM
  #4334
idrummerboy13's Avatar
Trader Rating: 15 (100%+)
this car is really tempting and I may just fall off the a.e slope. Maybe i just had a bad day bc usually my stuff feels real good but this car is really solid looking.
Jmuck ik u switched from b4.1 to this, what are the pros and cons? part breaks? shocks? diffs?
I would like a car that is easier to push harder.
idrummerboy13 is offline
Old 02-12-2012, 07:58 PM
  #4335
Autocratic's Avatar
Highly doubt they are "new" from TD. Probably something they did themselves.
Although, there was the long chassis at Reedy, and at this race as well. Hupo was also running the aluminum rear hubs at both races. Funny though, considering those things have been on the TD website for a few months now.
I was dreaming the other day of milling some material off the motor plate. It's already pretty thick and getting some mass off the top should help with CG; how much, is probably not very noticeable though.
The drilled slipper plates cuts rotational mass, which is always a good thing if you're looking for acceleration.
Also, from the pictures Hupo stuck with the long chassis, but switched to the stock TD body. He was running the Proline at Reedy. Jorn switched to the short chassis.
