Kyosho MP9E Thread
#91
I just recieved my two MP9e bodies from Kyosho America last week. Not sure if they still have stock left though. I had mine on backorder as soon as I found the part number on RC tech from someone. They are in for paint right now.
#92
Anyone knws which body I can use on my MP9. My sides are pretty high on 1 side cause I have 2 x 2s lipos stacked. Any body has higher sides?
I have some measuring. Will need abt 6.5 - 7cm of side height clearance.
#93
you can try the jconcepts body it will have more room than the stcok kyosho body you can also shim youre front body mount up a little to get a little extra room
#94
Does anyone have the JConcepts MP9 and can help me measure the side height clearance?
#96
I need more height. So which has more side height clearance? The RC8e or JConcepts MP9 body?
#97
the Jconcepts body DID NOT work with my 2 2s battery combo. I had to get the new Kyosho body. My batteries are Peak 5400 45c. They are in the hard case. 1.8275" sitting on there side.
#98
I'm using the RCPD Battery Tray with 2 x 2s stacked on top of each other. There's no space in the tray to stack them side by side. Tht's y I need a high side clearance. U can measure what's the side height clearance for the Kyosho body?
#99
untrimed the JC is 2.15...Kyosho trimed 2.20. I have the kyosho kit and these batteries just fit.
#100
i mounted my batteries and measured the top of my batteries from the top surface my chassis and its 2.18.
#101
In inches?
#102
If that's in inches, it's tough luck for me. I will need abt 2.6in to have enough clearance.
#103
yes, thats inches.
#104
my straps are above that...thats just the measurement to the top of the battery. 4s batteries are smaller.
#105
Mind helping me to measure your bodyshell from the inner and take the max height on the battery side? Tht'll be most accurate. Thanks.
