Kyosho MP9E Thread
#3241
Next question....my new MP9e came with ridiculous toe out....I want to adjust it, Kyosho manual doesn't state what size the turnbuckles are to adjust toe out/in...anyone know what size the turnbuckle nuts are? I was looking at the Losi turnbuckle wrench, it has 3.5, 4 and 5mm size wrenches all in one, but dont want to blow the money if it's not going to work...
#3242
I dont know what an ackerman plate is, or what kyosho truggy model ball ends you are talking about...interested to know though!
Also, i learned that the high traction low mount rear wing stays does not work on the MP9e TKI...it would take a bit of modification with a dremel to make work, which I might try later, but for now, I just put the original wing stay back on the car....
#3243
Sweet, ordered and received the 5.5 wrench, no more super toe out! Thanks!
https://www.amainhobbies.com/kyosho-...oif517/p784998
https://www.amainhobbies.com/kyosho-...is053b/p895884
#3244
IFW460
and this is my car rtr set I bought:
30874T1B
the notch in the front of the wing stay doesnt fit in the shock tower brace where it is suppose to...probably means i have older style shock tower braces ( just a guess)....it might fit if I dremeled the wing stay a bit...
sent some links, but apparently I haven't posted enough to put links in my replies yet
#3245
I can’t quite picture the issue. I assume the plastic block that fits to the gearbox and strut you either swapped or it is the same as the one on the tree. If you can add a picture that might help but yeah a dremel sometimes makes for a handy crafting tool. The MP10 mount is quite high so your old mount is actually back in style.
#3246
Best price
Hi all.
I am looking to buy a new Mp9e kit. Who has the best service/price currently?
i see notes earlier in the thread where members were finding prices in the $620 range. I'm finding $699 right now.
Anyone know of some good deals?
thank you Ron
thank you Ron
#3247
Amain with a discount coupon is $664. usually very good shipping rates.
#3248
Thank you for the replies Guys.
I am interested in the kit car only
#3251
Tower does not carry the KYOSHO buggies
#3253
Hello all,
I apologize if this has been answered.
What parts do i need to convert my MP9E evo into a “MP10E’ Evo??
#3254
Another forum member mentioned the MP10 arm droop screws are set further out and therefore will not contact the MP9 chassis. If that's the case, no good. It says you have an MP10, I think it's worth testing just to be sure....
#3255
Another one for you guys....my mp9e came with the standard thickness shock towers...will the thicker shock towers from an mp9e tki3 fit my car? I would insert the picture of the stays i am talking about, but I am not allowed to for some reason...
if someone could post pics of the thicker stays that i want to use i could verify we are talking about the same ones...
