*****YOKOMO BMAX 4***** >
Like Tree5Likes
Old 11-11-2013, 05:48 AM
  #991
Originally Posted by ColbyRichards
Yes! Now let's all bug Paul on their thread for some 12mm fronts to match! I love the mono wheels!
As a stop gap you can get the 9.8mm front adapter hex and get the B44.1 front mono wheels to match
zzztech is offline
Old 11-11-2013, 06:08 AM
  #992
dikke hond's Avatar
Would like to have the Rulux with 12mm hex!!
dikke hond is offline
Old 11-11-2013, 06:51 AM
  #993
What setups are you guys using, and are you guys buying any machined pistons for this kit?
I find the stock shocks & pistons to be a little "scratchy" and not nearly as smooth as my Kyosho shocks on my 1/8 for example. They seem to be pretty crap at best by comparison. Is this just standard for 1/10?
codeman is offline
Old 11-11-2013, 07:40 AM
  #994
I got machined pistons 6 holes and 2 holes and its very smooth
If you want less stiction get the Kyosho P3 O-rings
zzztech is offline
Old 11-11-2013, 07:54 AM
  #995
jk3
Is that 1.1 6 hole and 1.6 2 hole
jk3 is offline
Old 11-11-2013, 07:58 AM
  #996
1.1X6 front and 1X6 rear
I have used 1.7x2 all round with good success in the previous Bmax4
zzztech is offline
Old 11-11-2013, 08:25 AM
  #997
jk3
What did you mean 1x6 rear
jk3 is offline
Old 11-11-2013, 08:29 AM
  #998
http://www.rc-race-and-drift-japan.c...oducts_id=2123
Flat no taper
zzztech is offline
Old 11-11-2013, 11:12 AM
  #999
ColbyRichards's Avatar
Do you know the part numbers for that? Thats a good idea
ColbyRichards is offline
Old 11-11-2013, 11:37 AM
  #1000
Panic09's Avatar
Anyone knows where I can get some blank pistons ? or maybe use from another brand?
Panic09 is offline
Old 11-12-2013, 01:54 AM
  #1001
alrite folks. have updated post #975 and completed the build, with electronics setup.
am now busy painting the body for a run this coming weekend.
cheers
viktozzz is offline
Old 11-12-2013, 08:56 AM
  #1002
dMITIj's Avatar
cheers
Thanks, nice job
Could the "problem" with the shock be that the shocks should be on the other site of the tower?
if you look at the pic. from:
http://www.teamyokomo.com/product/of.../b_max43g.html
you can see that the shocks is on the back side of the tower
dMITIj is offline
Old 11-12-2013, 11:34 AM
  #1003
Trader Rating: 24 (100%+)
These Kyosho pistons should work.
newob is offline
Old 11-12-2013, 02:20 PM
  #1004
jk3
Originally Posted by dMITIj
Thanks, nice job
I beleive its an option in the kit that you can mount in front or back...
jk3 is offline
Old 11-12-2013, 02:21 PM
  #1005
Thanks, nice job
The shocks can be mounted on both sides. The manual state for it to be front side rather than rear side.
Though is it not stated in the manual, the rear side shocks position should be better for big and long jumps. Would keep the car more composed when landing
I realised that Naoto setup at worlds is rear shocks position, and other races using the front position.
I believe that this is an additional tuning option for us again
viktozzz is offline
