*****YOKOMO BMAX 4*****
#1697
#1705
I'm getting some play when the shock shafts are all the way out let's air in how can I fix this I heard AE o rings or so ?????????
#1708
I've just installed on mine, and is anxious to try it on the track.
#1710
Hi Fatbear
They are shorter. The reason is if you run the standard length rear shafts whilst running the inner most hole on the lower arms and lowest hole on the shock tower configuration the rear drive shaft can come out of the drivecups if you hit a jump hard enough. So rather than running more limiters internally in the shock he is running a shorter shaft. Just allows you to still utilize the full shock/piston travel without the drive shaft coming out. In saying that you can run the lower shock tower hole and middle hole in the lower arm with the standard length shaft without a problem. Hope this helps?
