MAX AMPS - 30C Lipo 6500 4S2P 14.8V Battery Pack
#31
How much do I save?
You begin the program at the "Basic" level. That means you get 5% off of everything on the website.
Once you spend $100.00 with MaxAmps.com then you hit the "Bronze" level. At this level you will get 10% off everything on the website.
Once you spend $500.00 with MaxAmps.com then you hit the "Silver" level. At this level you will get 15% off everything on the website.
Once you spend $2500.00 or more with MaxAmps.com then you hit the "Gold" level. At this level you will get 20% off everything on the website.
How long do I stay at my level?
The levels are based on your last 12 months purchases, so as long as you continue to purchase the minimum for your level with the past 12 months, you will stay at that level.
What else do I get?
What else do I get?
#33
JAM MAXAMPS,i am running the losi 8ight-e 2.0 with the 2100 xcelorin with the losi 4s 5000 and the most i can seem to get is 15.5 mins run time.how much more do you think i could get with your 6500 4s pack?also,i want to use the losi ec5 connector like the esc has but dont see that option.is it possible to get that connecter on it?one mor q,also the balnce plug i use is the reg old eflite plug.is that also an option or will i have to solder my own on?thanks for your time,JEREMY
#35
not counting the "issues" with the rateings, why are maxamps packs sooo much more than a SMC,CBP,NEU,etc batts of ~the same ratings and Mah???
#36
Have a happy 4th of July all,
Jason
#37
