SC10 Thread
Old 04-01-2012 | 11:56 AM
  #11011
Mizchief's Avatar
Originally Posted by Chris Gierse
Is anyone having much luck with a gear diff in this truck. I have tried it before and not been too happy with it but it seems to me like i read somewhere you can take the internal gears from an SC10 4x4 gear diff and use them in the 2wd gear diff. Is this true? If so, does it perform any better than the original gear diff? Thanks for the help.
IF that is the case can you replace the entire diff with the 4x4?
Mizchief is offline
Old 04-01-2012 | 01:32 PM
  #11012
Not sure. I just THINK that I read the internals are replaceable between the two and it was supposed to provide better diff action with the 4wd internals. Just going off of memory though. Was looking for some real world experience. Tired of rebuilding Ball Diffs!
Chris Gierse is offline
Old 04-01-2012 | 03:34 PM
  #11013
1Fastpede's Avatar
Anyone reccomend a gearing combo for 17.5 blinky? medium/small track
1Fastpede is offline
Old 04-01-2012 | 03:55 PM
  #11014
I would like to see what everyone is running?
I was running 75/28 little hot for me 5/6 mins about 160 degrees. Now I'm running 75/26 with little timing on end bell motor 5/6 mins 150 degrees just as much torque faster top end. Next time might take a little timing out bring temps down.
kahuna2793 is offline
Old 04-01-2012 | 08:00 PM
  #11015
jmc5313's Avatar
Default Servo Horn
I've looked everywhere for the right answer....What is the correct servo horn for an XP 1313....I was running a j horn and I believe it stripped...or is not the right one...
jmc5313 is offline
Old 04-01-2012 | 08:03 PM
  #11016
Mxer59's Avatar
It's the F horn
Futuba, Savox, Xp 25t servos
J Horn I'm not quite sure I've heard Jr has different sizes
Mxer59 is offline
Old 04-01-2012 | 08:05 PM
  #11017
Mizchief's Avatar
I'm running a D3 at 26/84 with 1.5+ notches on the motor and around 40deg of boost, sorry forget the range it kicks in. Comes off after a main around 145deg
It's got plenty of low end, but I need to squeeze a little more top end out of it.
Mizchief is offline
Old 04-01-2012 | 08:21 PM
  #11018
trickedout's Avatar
How were you able to fit 75/28? I run 75/26 with my D3 and I can't fit anymore.. I run full can timing and blinky from a Tekin and it's good for our med/large track but I'd like to try just a bit more but could t fit a 27 or 28.
trickedout is offline
Old 04-01-2012 | 08:27 PM
  #11019
Jorge T's Avatar
Default Using spacer to widen rear 2mm without stripping wheels
I have a bunch of tires mounted on regular offset hex wheels. In the front I can use a 2mm spacer and by using a serrated nut it will not come off. But in the back its another story, adding 2 mm spacer is asking for a stripped wheel.
So I tested using 2- 1mm spacers, one on the inside and one on the outside of the hex and can say they have held up very well.
Running a Reedy 7.5 on a med-high bite clay track with big jumps.
Attached Thumbnails SC10 Thread-2012-03-06-18.29.21.jpg   SC10 Thread-2012-03-06-18.34.08.jpg
Jorge T is offline
Old 04-01-2012 | 10:29 PM
  #11020
I run Orion vortex pro stock 17.5 I have room for 75/30
Old 04-01-2012 | 10:43 PM
  #11021
RCJesus's Avatar
Counter sink M3 Metric motor screws with those counter sink washers or button head screws in motor then you will have more room for larger pinions, I have run 75/29 could prob even go bigger. 6mm screws are what you want for button heads, and 8mm for the counter sink ones as they measure the head and all with counter sink screws.
I Prefer the counter sinks with counter sink flat washer
RCJesus is offline
Old 04-01-2012 | 11:57 PM
  #11022
RCJesus's Avatar
RCJesus is offline
Old 04-02-2012 | 02:47 AM
  #11023
darryl80's Avatar
Thumbs up
would a 75/28 spur/pinion combo work on a novak ballistic 8.5 motor?
darryl80 is offline
Old 04-02-2012 | 06:45 AM
  #11024
J_Bone's Avatar
I would start with 20/84.
J_Bone is offline
Old 04-02-2012 | 09:56 AM
  #11025
I am currently trying to dial in that same setup. I started with a 22/78 (way too low) and have worked my way up to 28/78 which I was running yesterday and the highest temperature reading I could get was 123 degrees running full packs back to back. I have a 30 tooth pinion and a 75 tooth spur to try out next time I am at the track.
I am using a Novak Ballistic 17.5 with a Mamba Max Pro set to use "Smart Sense" with normal timing. The physical timing on the motor is as it came from the factory.
-Chocula
Chocula is offline
