SC10 Thread
Old 08-27-2009 | 06:41 AM
  #2491
OG RC 10T's Avatar
Originally Posted by OCKyosho
waht zippy and turnigy lipos fit the sc10 and would be good for spec class racing
Almost any standard stick type pack will fit. The battery hold down is adjustable so if you get a large mah pack that is taller than average you can adjust for the height.
OG RC 10T is offline
Old 08-27-2009 | 06:56 AM
  #2492
CBHVR6's Avatar
the slippers tight and i've even tried 23/75. this isn't my first build and i'm not new to this. This is just so strange. I know there are lots of variables and you can't solve it from over the computer. I just thought some input may lead me in the right direction
CBHVR6 is offline
Old 08-27-2009 | 08:45 AM
  #2493
revracr909's Avatar
Originally Posted by rcmark24
75/27 or 28 and check your temp after 5 min.
Thanks rcmark
revracr909 is offline
Old 08-27-2009 | 09:42 AM
  #2494
OG RC 10T's Avatar
I was meaning with an 87 spur, not 75, which might be the issue. The pinion is near right but the spur is too small.
If you still have your 87 spur try 20 / 87
Old 08-27-2009 | 10:00 AM
  #2495
CBHVR6's Avatar
alright and yeah i knew what you meant. I am just saying i've even tried 23/75 to speed and it isn't there
CBHVR6 is offline
Old 08-27-2009 | 10:34 AM
  #2496
trdsupra88's Avatar
So i drove mine for the first time yesterday, and it is slow!
Tell me what i'm missing, it just doesn't go anywhere.
Castle 4600, Mamba Max, SMC 2s 40c 5200mah, 18/87
it should not be that slow!
I am running a similar setup and it is fast enough...check your ESC setting with the link to see if something changed. I am running on an 1/8th track with 17/87 and smaller LiPos and keep up with 10 and 13.5s
trdsupra88 is offline
Old 08-27-2009 | 10:43 AM
  #2497
Phazewun's Avatar
4600 is slow !
The problem is if you goto a 5700 you have to leave the punch controll @ 0, and you have to keep the motor timing on low. Altho everyone that told me a 5700kv would be to fast, i have to say you are wrong, 1/4 the way down the straight im to the floor all the way into the sweeper.
Im going to do a ball diff this weekend and it will be totally dialed.
Phazewun is offline
Old 08-27-2009 | 10:54 AM
  #2498
trdsupra88's Avatar
You must have more control than I do...4600 is still a handful...We will see what happens when I ditch the stock tires for some bowties or goosebumps...
Old 08-27-2009 | 11:02 AM
  #2499
whipnet's Avatar
trdsupra88 - Love the avatar. I still play that game... lol
whipnet is offline
Old 08-27-2009 | 11:12 AM
  #2500
trdsupra88's Avatar
Thanks, I stractched the disk so I havent plkayed in a while. I like the grocery store and garden stage. I have been looking for my whiplash disk, that game is just as old and just as fun...
Old 08-27-2009 | 11:19 AM
  #2501
whipnet's Avatar
I downloaded 100's of custom tracks and cars during it's heyday. Used to be some great online play.
OK back on topic....
whipnet is offline
Old 08-27-2009 | 12:06 PM
  #2502
Originally Posted by revracr909
Thanks rcmark
you need to worry about your shocks son! lol
Pimpin is offline
Old 08-27-2009 | 12:08 PM
  #2503
all i gotta say is you will never go back.....NEVER. lol
Pimpin is offline
Old 08-27-2009 | 12:10 PM
  #2504
Phazewun's Avatar
Lol wow you havent even changed the tires yet....
I changed to bowties and with the gear diff and correct camber and toe, you can controll it. the only hard part is when the wheels come off the ground and you smack into the timing pole
ive seen the 4600 pull the front wheels off the ground down the straight with the goosebump tires, but ive had nothing just good laptime with the m3 bowties so thats what i stick with.
Phazewun is offline
Old 08-27-2009 | 12:12 PM
  #2505
now that was funny.
Pimpin is offline
