HoBao Hyper 9E thread
#796
Edit: NM Its actually 8mm shorter.... ah
#802
So, will it fit?
#803
the 1800 will fit, it's the same length as the 2600. the 2200 will fit also as it's 76mm in length and the wires come out the side rather than the nue that comes out the endbell side making it harder to fit at the same length. the motors longer than 76mm are to big to fit and won't be roar approved and are made more for a truggy
#804
Some people talked of having a small amount of pinion choices and the fins having to be sanded off, anyone have any experience?
#805
According to the Tekin RX8 thread the new ones are running strong and holding up well. The Tekin tech guys say it was a manufacturing issue with an automatic soldering machine, and has been corrected.
#806
Tech Legend
was looking at the wrong specs. Good stuff the 1800 will be a great addition.
The issue with pinion size is that the car appears to have been designed with motors like a speed passion or novak in mind. Smaller cans. Smallest I have heard fit with trimming was a 14T pinion with the Tekin and Neu style cans.
So you want to go with a lower KV motor like a 1900Kv on 4S setup.
#808
Well, I picked up a 1512.1.5y. I report on how it fits.
#809
The 1412 NEU's are 36mm diameter motors, allows you to use the stock heatsink and pretty much any pinions. http://www.castlecreations.com/produ...rs/nm1400.html
Some pics of my street rocket 9e with a Tekno NEU 1509/2D/F 3300kv on 3s with a 13 tooth pinion (ground some of the first two rows of fins off.
#810
Anyone hear how these are doing at the 1/8 ROAR Electric Championships? I've got mine listed for sale right now. Just curious to see if the results will help or hurt the sale.
