Re-released Vintage Tamiyas
#31
Is anyone here familiar with the Fire Dragon/Thundershot type of transmission assembly?
Last night, I finished up both transmissions and what seemed odd were the two outdrives that slide into the differential assembly. Seems a little loose and so I was wondering if it's supposed to snap into place? Right now, the only thing preventing it from sliding out are the dog bones. Even then, there's a bit of play in the dog bones so the outdrives can slide out a bit.
#33
I guess no one knows about the outdrive issue with the Fire Dragon/Thundershot?
Well, here's a new question on the ESC that came with this kit, the Tamiya TEU-101BK. There's a extra pair of leads that is supposed to go to the receiver's battery port. Is this necessary? I thought that the ESC's power was directly drawn by the battery wires and the power is fed forward into the receiver through the receiver connectors on the ESC?
Does anyone here have much experience with this ESC? Also, what's the motor limit of this ESC?
#34
The TEU101-BK does not have BEC circuitry -- it draws its power through that little pair of leads. You can plug it into the receiver, but if your receiver doesn't have BEC either it will then supply full battery voltage to the receiver and ESC instead of the 6.0V they're supposed to get. Most receivers these days don't have BEC since pretty much every ESC does.
That being said, I ran this way (no BEC) in my Mini Cooper for a long time with no ill effects.
That ESC isn't good for much more than a black can (Sport Tuned).
#36
If you don't know about this site, it's a great source for Tamiya knowledge, both vintage and current:
http://www.tamiyaclub.com/
#37
Thanks Pete, I've been checking that site quite often. My only problem is, the forum usage and everything else requires subscription ($$$).
I just pulled off the servo connector from the 4xAA-Cell cradle that came with my Airtronics radio set and carefully slid out the plugs on the "battery" plug of the TEU-101BK and replaced the receptacle with the Airtronics one. As you guessed it, I"m using an Airtronics receiver, and the battery plug that is defaultly on the TEU-101BK doesn't fit into there.
I appreciate all the help. Attached are the pictures of my Fire Dragon, completed, I hope you and others on this board enjoy it. Well, completed up to this point. The only thing left to do is replace the Tamiya connector with the Duratrax Powerpoles (all my packs uses this connector) and setup the ESC after I fire it up for the first time (pardon the pun).
#39
Go to your local Wal-Mart and look in the toy section for "Micro Terrain Titans." They're ultra micro r/c versions of the old Tamiya buggies for $18! I got myself a micro Hornet the other day. They have working rear suspension and sort-of working front suspension and replica tires and rims. and the cars are about an inch or inch and a half in length. You can get the Hornet, Grasshopper, Avante, Frog, Boomerang, HotShot, Fox, and Rough Rider.
I'll throw up some pics of mine later today.
#40
Sweet, I'm gonna look for some of those. I know they had them in Japan looking at some of the youtube videos of the review. Apparently, this idea came out of a partnership with Choro-Q, the makers of those miniature, pull-back and let it go cars (I had a bunch of them as a kid). Seems like a perfect opportunity to get a desktop Tamiya!
Found some off Amazon:
http://www.amazon.com/s/ref=nb_ss_gw...+titan&x=0&y=0
You gotta love those classic Tamiya spoiler quotes:
Avante - "Being Nuts is Neat"
hahaha. A while ago, I started a thread for people to post their favorite. Perhaps people can do it again on this one.... My other favorite one is the Hornet one:
Hornet - "Anytime Baby"
#42
Just saw on tamiyablog.com, they are re-releasing the Rough Rider/Buggy Champ
old skool!!
www.tamiyablog.com
old skool!!
www.tamiyablog.com
#43
old skool!!
www.tamiyablog.com
old skool!!
www.tamiyablog.com
I will certainly get one of these to go with my faithful re-re Frog and run the crap out of it.
#44
I hope they have retro fitted something other than the hex drives, I had a blackfoot and was lucky to get 2 weeks from them.
