Associated SC10 CORR Truck, whose getting one?
#211
I figured it out and wrote it down, pistons, springs, oils.
It's all tweeners, none of it is exactly the same but very close.
Here ya go:
It's gonna go like this AE/Losi
Rear:
A Black 1.74/L White 1.8
A Green 1.90/L Yellow 2.0
A Silver 2.10/L Pink 2.3
A Grey 2.33/A Blue 2.55/L Red 2.6
A Gold 2.75/L Orange 2.9
A Red 2.95/L Silver 3.4
L Green 3.7/L Blue 4.1
Fronts:
A Blk 2.76/L Red 2.5
A Green 2.99/L Orange 2.9
A Silver 3.22/L Silver 3.2
A Blue 3.45/L Green 3.5
A Gold 3.70/L Blue 3.8
A Red 3.90/L Black 4.5
Pistons:
AE #1 is between Losi 54 and 55
AE #2 is between Losi 55 and 56
AE #3 is between Losi 56 and 57
Shock Oils:
I'm told Losi is 2.5 less than AE
ie, Losi 27.5 = AE 30
So if I want Losi shocks on my AE SC10 I'll do:
Losi 54 or 55 pistons (almost = AE #1) and white or yellow springs (almost = AE Green) on the REAR
Losi 56 or 57 pistons (AE # 3) and red or orange springs ( AE Gold) on the FRONT
Oil you can figure that out ez
#212
#213
Me getting mine was just dumb luck. I went to my L.H.S. to get parts for my xxx-cr and saw one up on the wall. It was the only one they got in and the only reason he got it was to look at part of the diff. He made me a sweet deal on it and it went home with me. I had been looking at them and wanting to get one poss., guess i was in the right place at the right time.
Anyways, got it last fri. night , built it, then raced on sat. SMOKED the slashes!!
I put in the smallest motor i had (10.5 novak ) set the epa to 80% and was dead even with the fastest slash there. Set T.Q. and won the main. So far i am loving it. just waiting to see how durable it is going to be.
#214
Matt,
Here ya go:
Rear:
Fronts:
Pistons:
Shock Oils:
Here ya go:
Rear:
Fronts:
Pistons:
Shock Oils:
#215
I live in Australia so its hard to call people who are 1 day behind a 9 hours ahead of us. I went to their website and printed off a missing or defective items form. If I send that to them, will there be no mucking around and just a pair of rear rims sent out?
#217
I broke my SC10 chassis and top plate last nite racing and made a plate today to fix it.
I ran this plate all day over the broken chassis and it works perfectly.
I did have to buy a new top plate for $7 tho.
I didn't have to change the chassis and everything on it.
Just bolt the plate to the 2 original bulkhead screws then drill 2 new holes under the servo (pull the servo first!) and put 2 new screws with nuts in the new holes, remount the servo and go racing again.
Should take about 10 minutes, no new chassis and no complete rebuild.
I hand made several of these plates to help you guys that WILL eventually break your chassis in the same place.
You can get one to fix your chassis or get one to prevent breaking your chassis and top plate.
Or you can go get an aluminum plate at the hobby store, cut it, bend it, drill it, countersink it and then bolt it on but you won't be racing the same day that's for sure!
$20 shipped for one of my "F N Racing Stuff" plates.
Get your paypal ready.
RB was kind enough to keep a couple at the track (OCRC HOBBIES AND RACEWAY) for those who mite want or need one.
#219
thats the 2nd broken chassis ive seen on this truck and in the same area
#223
http://www.rctech.net/forum/electric...ing-truck.html
#225
I'm running with a broken chassis that took 10 minutes to fix.
Less is more in this case, proven effective.
Hope your idea works out for you, sounds like a lot of work tho.
